IVR option to connect to Conference
Robert Birch
111
Hi there,
I've created a Conference extension which works correctly.
What I need is to be able to select the conference from the IVR menu. I set Option 999 and told it to point to the conference extension. When I dial thst xtension through the IVR, it just replays the greeting and never goes to the extension. Is 999 not a valid extension in IVR?
I also tried to set the Conference extension to 999 and try to dial it directly from the IVR, but that comes back with Invalid Entry.
Thanks for the help,
Robert Birch
Robert Birch
111
I think this is all of it. This is a production system with multiple calls going on at once. :)
  • freeswitch.txt
Robert Birch
111
I've included a screen shot of the conference setup. I have Direct Dial Extensions turned on in the IVR.
Thanks,
Bob
taptech
50
I have this working in one of my sub-domains:
Conference at extension 5000
IVR entry 5000 with destination set to Conferences - 5000
Works fine!
