Polycom IP 650 BLF
roger_roger
198
19
Hi-
I need to configure BLF on a Polycom expansion module for an IP 650. I want to do it in the device section in Fusion. Can anybody give me a pointer?
dougs
29
Have you tried just adding additional keys? you have 6 keys on the IP 650... a number of those are going to be taken up by the extension. So have you tried adding a 7th or 8th key to see if that works? It will on the VVX line, not sure on the Soundpoint IP line.
roger_roger
198
19
I was able to get help in the IRC chatroom. For reference, on the IP 650, you can't set the BLF to a specific key; they go in order. So, I set lines 1 through 6 to be the extension lines themselve and then the BLF lines started on the next available, which was the expansion module.
Len
95
you can try entering invalid speed dials and label them with a . just to use as a filler
