Requiring a PIN number for outbound calls
dougs
29
Seems the wiki is incorrect. http://wiki.fusionpbx.com/index.php?title=Outbound_Routes
To have the system ask for a PIN number before a call is made. A good use is if you don't want every user on the system to be able to call international destinations. Do the following:
Before the bridge action on the route add the following actions
action set pin_number=(Whatever pin number you choose)
action lua pin_number.lua
Also make sure pin_number.lua is in /usr/local/freeswitch/scripts/ (by default it is)
To use the "PIN Numbers" app to set multiple PINs then you must set the action pin_number=database.
Craig Fox
26
Is there any way to filter the PIN Numbers? I have been able to get it to work but having one pin# give access to every/any feature that is secured by pin_number=database.
kidjake28
97
I know this is an old topic but I haven't been able to find any documentation on fusionx members login.
pin_number=database;
Doesn't seem to tie into the PIN Numbers db.
If I manually enter
pin_number=1234
That works but after the lua script it just disconnects.
Any help appreciated.
bdmonsey
146
If I manually enter
pin_number=1234
This works for me. if it's an international carrier you might wanna check why it's being disconnected, it might be a prefix issue, Caller id issue, security issue.
Hope I was helpful
