E eman Member Jan 9, 2024 31 0 6 27 Apr 7, 2026 #1 good day Please help me, I'm having this issue where there are calls, but I can't see them on active calls, as it doesn't show real-time data of active calls . Please assist me if I'm missing something
P pbxgeek Well-Known Member Jan 19, 2021 947 308 63 39 Apr 7, 2026 #2 Have you tried pressing the circle arrow button to keep the page updating?
E eman Member Jan 9, 2024 31 0 6 27 Apr 7, 2026 #3 pbxgeek said: Have you tried pressing the circle arrow button to keep the page updating? View attachment 4906 Click to expand... yes i have but still i get nothing
P pbxgeek Well-Known Member Jan 19, 2021 947 308 63 39 Apr 7, 2026 #4 It's showing active calls for the tenant you are currently signed in to. You can click on the Show Global button to see all. Check the logs for any errors Retrieving Logs in FS PBX | FS PBX – Open Source PBX Dashboard for VoIP Providers In FS PBX, all application logs are stored inside the storage/logs directory. These logs record system activity, errors, and debugging information --- making them an essential tool when troubleshooting or checking system behavior. www.fspbx.com
E eman Member Jan 9, 2024 31 0 6 27 Apr 7, 2026 #5 'Websocket Disconnected' I'm getting this error when I run inspect. not sure how to work around this
P pbxgeek Well-Known Member Jan 19, 2021 947 308 63 39 Apr 7, 2026 #6 Then you are not running FS PBX, and you are probably running FusionPBX. This thread is for FS PBX users
P pbxgeek Well-Known Member Jan 19, 2021 947 308 63 39 Apr 7, 2026 #8 You should check out FS PBX (www.fspbx.com) when you have a moment. Fewer bugs and a much better front end for management. Reactions: RCCradio
