Automated external backups
Jeff.H
11
One thing I love about FreePBX and 3cx is the ability to run automated daily backups of my PBXs to an offsite FTP server.
I haven't yet been able to find that functionality with Fusion. Does it exist?
I have been running my PBXs on Digital Ocean for several years without incident (no jinx), but there have been times where something just happens and I have to restore from a backup, so I would really like to be able to continue to do that. I already have space on another provider where the backups reside that is already part of some hosting I have, so I would like to avoid having to pay DO for backups if I can do it myself. It also means that if something does happen at DO I have daily copies to restore from on another provider if needed.
Jeff.H
11
Yeah I saw that, but it seems like it still only does it locally and I have to manually download the file. I would prefer it to be able to send directly to my other server automatically. Unless I missed something.
ElecBoy
15
Well after the backup you can a a Crontab with SCP, and move it to another server.
Or you just map a directory to an NFS mountpoint. There are tons of ways to achieve this.
Jeff.H
11
Ok well this is where my limited linux knowledge rears its ugly head. I know "just enough" and have been spoiled by Ward's tutorials over the years. I'll go poke around and figure something out.
Jeff.H
11
Ok so I got my password from /etc/fusionpbx/config.php and went to setup the backup but when I went into ./fusionpbx-backup.sh it already had this info in it, but with a different password, which I have obscured to post here. Do I need to change anything or just keep this as is and set a cron to scp it? I ask because it looks different than the instructions linked above.
#!/bin/sh
#export PGPASSWORD="xxxxxxxxxxx"
db_host=127.0.0.1
db_port=5432
now=$(date +%Y-%m-%d)
mkdir -p /var/backups/fusionpbx/postgresql
echo "Backup Started"
#delete postgres backups
find /var/backups/fusionpbx/postgresql/fusionpbx_pgsql* -mtime +4 -exec rm {} \;
#delete the main backup
find /var/backups/fusionpbx/*.tgz -mtime +2 -exec rm {} \;
#backup the database
pg_dump --verbose -Fc --host=$db_host --port=$db_port -U fusionpbx fusionpbx --schema=public -f /var/backups/fusionpbx/postgresql/fusionpbx_pgsql_$now.sql
#package
tar -zvcf /var/backups/fusionpbx/backup_$now.tgz /var/backups/fusionpbx/postgresql/fusionpbx_pgsql_$now.sql /var/www/fusionpbx /usr/share/freeswitch/scripts /var/lib/freeswitch/storage /var/lib/freeswitch/recordings /etc/fusionpbx /etc/freeswitch
#source
#tar -zvcf /var/backups/fusionpbx/backup_$now.tgz /var/backups/fusionpbx/postgresql/fusionpbx_pgsql_$now.sql /var/www/fusionpbx /usr/local/freeswitch/scripts /usr/local/freeswitch/storage /usr/local/freeswitch/recordings /etc/fusionpbx /usr/local/freeswitc$
echo "Backup Completed"
Jeff.H
11
Found a few issues with the backup directions from the link above.
#delete postgres logs older than 7 days
find /var/log/postgresql/postgresql-9.4-main* -mtime +7 -exec rm {} \;
This needs to be changed from 9.4 to 10
#delete freeswitch logs older 3 days
find /usr/local/freeswitch/log/freeswitch.log.* -mtime +2 -exec rm {} \;
This doesn't seem to exist anywhere on the server that I can find
pg_dump --verbose -Fc --host=$database_host --port=$database_port -U fusionpbx fusionpbx --schema=public -f /var/backups/fusionpbx/postgresql/fusionpbx_pgsql_$now.sql
This results in this error, whether I use the existing password or the one I got from /etc/fusionpbx/config.php (pg_dump: [archiver (db)] connection to database "fusionpbx" failed: FATAL: Peer authentication failed for user "fusionpbx")
So, this is what I ended up with....
#!/bin/sh
db_host=127.0.0.1
db_port=5432
#delete postgres backups older than 7 days
find /var/backups/fusionpbx/postgresql/fusionpbx_pgsql* -mtime +7 -exec rm {} \;
#delete the main backup older than 7 days
find /var/backups/fusionpbx/*.tgz -mtime +7 -exec rm {} \;
find /var/log/postgresql/postgresql-10-main* -mtime +7 -exec rm {} \;
#package
#source
#tar -zvcf /var/backups/fusionpbx/backup_$now.tgz /var/backups/fusionpbx/postgresql/fusionpbx_pgsql_$now.sql /var/www/fusionpbx /usr/local/freeswitch/scripts /usr/local/freeswitch/storage /usr/local/freeswitch/recordings /etc/fusionpbx /usr/local/freeswitch/conf
Kenny Riley
243
Hi Jeff
I just configured this on my system today and it's working like a charm..
Make sure ftp is installed on your server first..
sudo apt-get install ftp
Then just add the following lines to your fusionpbx-backup.sh script after the database backup portion of it.
cd /var/backups/fusionpbx/postgresql/
ftp -n <<EOF
open YOUR-FTP-SERVER
user USERNAME PASSWORD
passive
prompt
mput fusionpbx_pgsql_$now.sql
quit
EOF
You'll want to obviously replace the variables above for your FTP server, username, and password.
You can use this same concept to transfer package files offsite as well if you wish.
Good luck.
Reactions: Jeff.H
Jeff.H
11
@Kenny Riley Thank you so much for that!!!
I did have to make a few small changes to get the actual backup.tgz moved over.
This is what I ended up with and it works perfectly.
ftp -n <<EOF
passive
prompt
mput backup_$now.tgz
quit
EOF
Kenny Riley
243
ftp -n <<EOF
passive
prompt
quit
EOF
Ahh yes, it looks like you are moving your package directories over. I'd strongly recommend backing up your database as well. Call recordings and such are great but without a database backup in the event of a disaster, you're screwed :)
Reactions: Jeff.H
Jeff.H
11
Ok yeah, good catch. I've changed it to look like this. One thing that seems to be a mystery though is that the .sql backup is a 0 byte file and if I open it in text edit its blank.
ftp -n <<EOF
passive
prompt
cd /Fusion/fusionpbx
quit
EOF
ftp -n <<EOF
passive
prompt
cd /Fusion/fusionpbx/postgresql/
quit
EOF
markjcrane
448
162
Sorry I'm not going to be popular for saying this but plain FTP is not secure and so it is not recommended to use.
You are far better off using something that is secure like one of the following sftp (ftp over ssh), rsync or scp.
