SOLVED Backup entries missing in Advanced / Backup
I have just installed on Debian 8.7.1 and am missing the source paths in Advanced / Backup.
I checked in Advanced / Default Settings and Backup is not referenced there either.
How can I fix this?
Thanks,
Scott
Reactions: Jean B
Hugh Blandford
Great, thanks! Is there a file somewhere to edit to add these?
Hi Scott,
this section is under Advanced - Default Settings
Put backup in the search box at the top. If nothing is returned, click on the + at the beginning of one of the sections.
Replace the category with backup and fill in the rest of the sections as you see in the graphic above.
Category: backup
Subcategory: path
Type: array
Value: <path>
Enabled: true
Click save and you will have created a new section. Repeat until you have covered all the items.
