Call Drop on eavesdrop usage.
Amit Iyer
56
11
I am receiving call drop as soon as i connect to an extension to listen / barge or Whisper.
Currently i am using it like this, i am dialing *33(extension number) and i enter the pin with # as soon as i do that my call gets disconnected.
2018-07-10 17:49:58.598114 [NOTICE] mod_dptools.c:1312 Channel [sofia/internal/999@eng2pbx.primetcm.com] has been answered
2018-07-10 17:49:58.598114 [DEBUG] switch_channel.c:3773 (sofia/internal/999@eng2pbx.primetcm.com) Callstate Change EARLY -> ACTIVE
2018-07-10 17:49:58.598114 [DEBUG] sofia.c:7084 Channel sofia/internal/999@eng2pbx.primetcm.com entering state [completed][200]
EXECUTE sofia/internal/999@eng2pbx.primetcm.com lua(eavesdrop.lua 998)
2018-07-10 17:49:58.598114 [DEBUG] freeswitch_lua.cpp:365 DBH handle 0x7fb754061550 Connected.
2018-07-10 17:49:58.598114 [DEBUG] freeswitch_lua.cpp:382 DBH handle 0x7fb754061550 released.
2018-07-10 17:49:58.598114 [DEBUG] switch_cpp.cpp:1112 sofia/internal/999@eng2pbx.primetcm.com destroy/unlink session from object
2018-07-10 17:49:58.598114 [NOTICE] switch_core_state_machine.c:385 sofia/internal/999@eng2pbx.primetcm.com has executed the last dialplan instruction, hanging up.
2018-07-10 17:49:58.598114 [NOTICE] switch_core_state_machine.c:387 Hangup sofia/internal/999@eng2pbx.primetcm.com [CS_EXECUTE] [NORMAL_CLEARING]
char1
Core.db should be in the directory set in menu advanced, default settings, db.
jeetz
73
@char1 is it here that i need to keep /dev/shm
basically iam looking a session that is kept alive (may be MOH), and as the callee gets a call then eavedrop on the call, and repeat the process, till the agent (using eavesdrop) drop hangup the call, my eavesdrop work, but disconnects when no one is on call
