CDRs not showing
Andyd358
243
UK
Checks CDRs this monring and none are showing since 17 May. Went to Advanced Upgrade Schema and updated it an dData types. CDrs then showed 1 call from today but no others. Seems Call recordings are not showing/bieng recorded either.
Where should I check next?
Andyd358
243
UK
Well last night I rebooted the server and now they are working again. But still a gap between 17th and now so dont kno wht happened, but hey its working aagin fo now .
gflow
262
Any errors in the freeswitch log and the the missing records actually in the database?
Andyd358
243
UK
When i check /var/lib/freeswitch/recordings/ I can see the recordings in there for the missing dates but they dont show on the GUI
