Centos/SL Linux letsencrypt script
bcmike
326
I have one server running Centos and I wanted to run the the letsencrypt script to setup ssl and TLS.
It turns out you only have to make three edits
1st the sed statements simply need to point to fusionpbx.conf instead of just fusionpbx:
sed "s@ssl_certificate /etc/ssl/certs/nginx.crt;@ssl_certificate /etc/dehydrated/certs/$domain_name/fullchain.pem;@g" -i /etc/nginx/sites-available/fusionpbx.conf
sed "s@ssl_certificate_key /etc/ssl/private/nginx.key;@ssl_certificate_key /etc/dehydrated/certs/$domain_name/privkey.pem;@g" -i /etc/nginx/sites-available/fusionpbx.conf
2nd you need to change the chown statement at the end to:
chown -R freeswitch:daemon /etc/freeswitch/tls
You might also have to restart nginx
Reactions: cemotyz09
TimGuyUK
105
This has got me further however Im getting file not found errors. Im guessing its permissions but Ive even given everyone access and I still cant get it to work.
The error is the error as root. Ive tried sudo freeswitch but I get a mountain of errors.
nginx: [emerg] cannot load certificate "/etc/dehydrated/certs/hostpbx01.domain/fullchain.pem": BIO_new_file() failed (SSL: error:02001002:system library:fopen:No such file or directory:fopen('/etc/dehydrated/certs/hostpbx01.domain/fullchain.pem','r') error:2006D080:BIO routines:BIO_new_file:no such file)
nginx: configuration file /etc/nginx/nginx.conf test failed
Any ideas?
Tim
