Conference center external not working.
ccoombes
12
Hi, I have recently setup a new Fusion PBX we are about to roll out and i am trying some features out.
We would like to use the conference center feature and i have setup a conference center and a room, it is working great on internal extensions but i would like the option for an external caller to join conferences too, preferably by entering a direct dial extension from an IVR menu but can use a DID if that is not possible.
I have tried setting an inbound route to the conference extension for externals and when connected i am not asked for a pin just told that i am the only person in the conference (even when a conference is in place). If i use another external line to dial in it joins the same pinless conference as the first line.
This would be a really handy feature to have if it is possible?
Fusion PBX 4.5.11 on Debian 10 Freeswitch 1.10.2
ccoombes
12
It works, you are doing something wrong, post a log.
I'm sure that is the case, there just is no documentation available for setting up conference center and allowing external access to it.
Which log would you like me to send?
fs_cli when the call is placed. I guess the reason there are no docs is that its simple. You should just need to point any inbound be it IVR, DID, whatever method at exactly the same place you would for an internal extension. You may possibly have hit a recent bug or something. I do this all the time from outside.
Reactions: ccoombes
ccoombes
12
I've sorted it, it was my inbound route that was wrong, I set to action conference 4000, setting transfer 4000 worked for the DID.
Is it possible to transfer to a conference room from IVR menu?
ccoombes
12
Yes, just point the ivr entry to 4000
Below is the log from direct dialling 4000 from IVR. (As you could for any other extension).
However, in doing what you suggested and creating an IVR option to point to 4000 it does work as expected, 4000 was not in the list of available options but manually typing it does work so I have a solution.
2020-02-07 13:31:02.813255 [DEBUG] switch_ivr_menu.c:562 action regex [4000] [/^(\d{2,11})$/] [2]
2020-02-07 13:31:02.813255 [DEBUG] switch_ivr_menu.c:580 IVR action on menu '6e277b28-1f04-4fd0-a7e7-95a19c07528a' matched '4000' param 'playback ${cond(${user_exists} == true ? /usr/share/freeswitch/sounds/${default_language}/${default_dialect}/${default_voice}/ivr/ivr-call_being_transferred.wav : /usr/share/freeswitch/sounds/${default_language}/${default_dialect}/${default_voice}/ivr/ivr-that_was_an_invalid_entry.wav)}'
2020-02-07 13:31:02.813255 [DEBUG] switch_ivr_menu.c:584 switch_ivr_menu_execute todo=[2]
EXECUTE [depth=0] sofia/external/00000000000@*********** playback(/usr/share/freeswitch/sounds/en/us/callie/ivr/ivr-that_was_an_invalid_entry.wav)
2020-02-07 13:31:02.813255 [DEBUG] switch_ivr_play_say.c:1492 Codec Activated L16@16000hz 1 channels 20ms
2020-02-07 13:31:04.473252 [DEBUG] switch_ivr_play_say.c:1933 done playing file /usr/share/freeswitch/sounds/en/us/callie/ivr/ivr-that_was_an_invalid_entry.wav
2020-02-07 13:31:04.473252 [DEBUG] switch_ivr_menu.c:562 action regex [4000] [/^(\d{2,11})$/] [2]
2020-02-07 13:31:04.473252 [DEBUG] switch_ivr_menu.c:580 IVR action on menu '6e277b28-1f04-4fd0-a7e7-95a19c07528a' matched '4000' param 'transfer ${cond(${user_exists} == true ? 4000 XML ***.******.co.uk )}'
2020-02-07 13:31:04.473252 [DEBUG] switch_ivr_menu.c:584 switch_ivr_menu_execute todo=[2]
