Debian 10 install UFW problem
dcitelecom
181
When installing fusionpbx on debian 10 (buster), the fusionpbx web GUI is not accessible because the install script can't handle the new UFW firewall. Debian 9 uses iptables and 10 uses UFW. I can access the GUI if I turn off the UFW firewall but that's not really a solution.
Installing on Debian 9 works fine. I was also able to upgrade the system to Debian 10 afterwards without any issues. It's just that a straight install to Debian 10 doesn't work.
Why is turning off UFW not a solution? iptables is still there and you can configure it as you wish, without UFW.
Because in the Debian 9 install fusionpbx sets up all the iptables default rules whereas in the Debian 10 install, it doesn't seem to do it.
