Debian 12 (IONOS) + nftables + DjangoPBX — Essential Steps
lidiomar
Hi Guys.
Recently I needed to apply adjustments to Debian 12 on VPS Ionos to successfully complete the DjangoPBX installation. Details are provided below to help anyone who needs them.
Context (IONOS VPS)​
  • Debian 12 is delivered without nftables installed
  • iptables exists only for compatibility (nf_tables backend)
  • The firewall is fully open by default
  • For DjangoPBX / FreeSWITCH, a controlled firewall is strongly recommended ;)
  • 1️⃣ Ensure SSH access (critical step)​
    Before changing the firewall:
    iptables -I INPUT -p tcp --dport 22 -j ACCEPT
    2️⃣ Remove iptables persistence (if installed)​
    apt purge iptables-persistent -y
    rm -rf /etc/iptables
    3️⃣ Install nftables​
    apt update
    apt install nftables -y
    Main configuration file:
    /etc/nftables.conf
    4️⃣ Create a base nftables firewall​
    Edit the file:
    nano /etc/nftables.conf
    Example configuration for DjangoPBX / FreeSWITCH:
    #!/usr/sbin/nft -f
    flush ruleset
    table inet filter {
    chain input {
    type filter hook input priority 0;
    policy drop;
    iif lo accept
    ct state established,related accept
    tcp dport 22 accept
    tcp dport {80,443} accept
    udp dport 5060 accept
    tcp dport 5060 accept
    udp dport 16384-32768 accept
    ip protocol icmp accept
    chain forward {
    type filter hook forward priority 0;
    policy drop;
    chain output {
    type filter hook output priority 0;
    policy accept;
    5️⃣ Apply and test the rules​
    nft -f /etc/nftables.conf
    nft list ruleset
    Verify:
    • SSH access
    • DjangoPBX web interface
    • SIP registration
    • RTP audio flow
  • 6️⃣ Enable nftables at boot​
    systemctl enable nftables
    systemctl start nftables
    ✅ Result
    • Debian 12 running native nftables
    • Persistent and secure firewall
    • Fully compatible with DjangoPBX + FreeSWITCH
    • No iptables dependency
    • Ideal setup for IONOS VPS
enjoy ;)
Leave your feedback if this was helpful.
Just be aware that using the nftables rule set above, will mean that non of the counters or sets that DjangoPBX interacts with will be available. Any firewall related activity will fail. For example, when someone requests too many URLs that do not exist, their IP address is automatically put into a web block list, this operation will fail if the list is not configured in the firewall.
