Fresh install issue
Andyd358
243
UK
Hi
Version 4.5.14
Git Information Branch: master
Debian 9.12
5 times today I have tried to install Fusion on a debian CT in proxmox each time I get the same problem I can add a gateway but it wont start and when i click on sip status I get "connection to event socket failed" also if i look at the log viewer it seem a little broke!!!
Any Ideas?
The only thing i can think of is that there may be an issue with proxmox. I know it does not like its IP address changed but it was setup on dhcp in a different location so I had to chaneg the ip and dns for it.
364
Last person I remember having that sort of trouble had accidentally installed the 32 bit version of Debian.
Andyd358
243
UK
initially i was getting lots of locale errors directory not found when i was trying to install via ssh but ive since tried using the console on proxmox, dont get the errors any longer but still the same outcome.. I had the same issue with trying in on raspberry pi earlier in the week.
Andyd358
243
UK
Only error i get when installing again (Debian 10 standard) this time is
Ver Cluster Port Status Owner Data directory Log file
11 main 5432 down postgres /var/lib/postgresql/11/main /var/log/postgresql/postgresql-11-main.log
update-alternatives: using /usr/share/postgresql/11/man/man1/postmaster.1.gz to provide /usr/share/man/man1/postmaster.1.gz (postmaster.1.gz) in auto mode
Setting up postgresql (11+200+deb10u3) ...
Setting up sysstat (12.0.3-2) ...
Andyd358
243
UK
Seen another error at the end of the install
Job for freeswitch.service failed because the control process exited with error code.
See "systemctl status freeswitch.service" and "journalctl -xe" for details.
* freeswitch.service - freeswitch
Loaded: loaded (/lib/systemd/system/freeswitch.service; enabled; vendor preset: en
Active: failed (Result: exit-code) since Fri 2020-06-12 17:07:39 UTC; 22min ago
Process: 15918 ExecStartPre=/bin/mkdir -p /var/run/freeswitch (code=exited, status=
Jun 12 17:07:39 CT100 systemd[1]: freeswitch.service: Service RestartSec=100ms expire
Jun 12 17:07:39 CT100 systemd[1]: freeswitch.service: Scheduled restart job, restart
Jun 12 17:07:39 CT100 systemd[1]: Stopped freeswitch.
Jun 12 17:07:39 CT100 systemd[1]: freeswitch.service: Start request repeated too quic
Jun 12 17:07:39 CT100 systemd[1]: freeswitch.service: Failed with result 'exit-code'.
Jun 12 17:07:39 CT100 systemd[1]: Failed to start freeswitch.
lines 1-11/11 (END)
364
Difficult to call, but this may be a permissions issue. You really need some input from a Proxmox expert.
Andyd358
243
UK
Could it be because im using proxmox do you think Ive never had an issue like this before, coul dit be related to this:
364
I don't know the answer. I know @DigitalDaz has some experience with Proxmox, maybe he (or others) will be able to provide a more educated guess than me.
Andyd358
243
UK
Stangley I have had the same problem with a Raspberry Pi so i was thinking is there a proble with the master
Andyd358
243
UK
Thought i would try again this morning but still getting the same error :
Success. You can now start the database server using:
pg_ctlcluster 12 main start
12 main 5432 down postgres /var/lib/postgresql/12/main /var/log/postgresql/postgresql-12-main.log
update-alternatives: using /usr/share/postgresql/12/man/man1/postmaster.1.gz to provide /usr/share/man/man1/postmaster.1.gz (postmaster.1.gz) in auto mode
Setting up postgresql (12+215.pgdg90+1) ...
Processing triggers for systemd (232-25+deb9u12) ...
CREATE DATABASE
CREATE DATABASE
CREATE ROLE
CREATE ROLE
GRANT
GRANT
GRANT
ALTER ROLE
ALTER ROLE
INSERT 0 1
INSERT 0 1
INSERT 0 1
Andyd358
243
UK
Loaded: loaded (/lib/systemd/system/freeswitch.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Mon 2020-06-15 08:08:56 UTC; 35min ago
Process: 18034 ExecStartPre=/bin/mkdir -p /var/run/freeswitch (code=exited, status=214/SETSCHEDULER)
Jun 15 08:08:56 CT100 systemd[1]: freeswitch.service: Control process exited, code=exited status=214
Jun 15 08:08:56 CT100 systemd[1]: Failed to start freeswitch.
Jun 15 08:08:56 CT100 systemd[1]: freeswitch.service: Unit entered failed state.
Jun 15 08:08:56 CT100 systemd[1]: freeswitch.service: Failed with result 'exit-code'.
Jun 15 08:08:56 CT100 systemd[1]: freeswitch.service: Service hold-off time over, scheduling restart.
Jun 15 08:08:56 CT100 systemd[1]: Stopped freeswitch.
Jun 15 08:08:56 CT100 systemd[1]: freeswitch.service: Start request repeated too quickly.
Jun 15 08:43:21 CT100 sshd[19242]: Received disconnect from 49.88.112.76 port 34039:11: [preauth]
Jun 15 08:43:21 CT100 sshd[19242]: Disconnected from 49.88.112.76 port 34039 [preauth]
Jun 15 08:43:21 CT100 sshd[19242]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=49.88.112.76
Jun 15 08:43:53 CT100 sshd[19260]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=218.
Jun 15 08:43:55 CT100 sshd[19260]: Failed password for root from 218.92.0.173 port 22922 ssh2
Jun 15 08:43:58 CT100 sshd[19260]: Failed password for root from 218.92.0.173 port 22922 ssh2
Jun 15 08:44:01 CT100 sshd[19260]: Failed password for root from 218.92.0.173 port 22922 ssh2
Jun 15 08:44:04 CT100 sshd[19260]: Failed password for root from 218.92.0.173 port 22922 ssh2
Jun 15 08:44:07 CT100 sshd[19260]: Failed password for root from 218.92.0.173 port 22922 ssh2
Jun 15 08:44:07 CT100 sshd[19260]: error: maximum authentication attempts exceeded for root from 218.92.0.173 port 22922 ssh2 [
Jun 15 08:44:07 CT100 sshd[19260]: Disconnecting: Too many authentication failures [preauth]
Jun 15 08:44:07 CT100 sshd[19260]: PAM 4 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=218.92.0.173
Jun 15 08:44:07 CT100 sshd[19260]: PAM service(sshd) ignoring max retries; 5 > 3
Jun 15 08:44:16 CT100 sshd[19273]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=218.
Jun 15 08:44:18 CT100 sshd[19273]: Failed password for root from 218.92.0.173 port 61872 ssh2
Jun 15 08:44:21 CT100 sshd[19277]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=49.8
Jun 15 08:44:22 CT100 sshd[19273]: Failed password for root from 218.92.0.173 port 61872 ssh2
Jun 15 08:44:23 CT100 sshd[19277]: Failed password for root from 49.88.112.76 port 60386 ssh2
Jun 15 08:44:25 CT100 sshd[19277]: Failed password for root from 49.88.112.76 port 60386 ssh2
Jun 15 08:44:26 CT100 ntpd[1903]: local_clock: ntp_loopfilter.c line 818: ntp_adjtime: Operation not permitted
Jun 15 08:44:26 CT100 sshd[19273]: Failed password for root from 218.92.0.173 port 61872 ssh2
Jun 15 08:44:28 CT100 sshd[19277]: Failed password for root from 49.88.112.76 port 60386 ssh2
Jun 15 08:44:28 CT100 sshd[19277]: Received disconnect from 49.88.112.76 port 60386:11: [preauth]
Jun 15 08:44:28 CT100 sshd[19277]: Disconnected from 49.88.112.76 port 60386 [preauth]
Jun 15 08:44:28 CT100 sshd[19277]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=49.88.112.76
Jun 15 08:44:29 CT100 sshd[19273]: Failed password for root from 218.92.0.173 port 61872 ssh2
Jun 15 08:44:34 CT100 sshd[19273]: Failed password for root from 218.92.0.173 port 61872 ssh2
Jun 15 08:44:37 CT100 sshd[19273]: Failed password for root from 218.92.0.173 port 61872 ssh2
Jun 15 08:44:37 CT100 sshd[19273]: error: maximum authentication attempts exceeded for root from 218.92.0.173 port 61872 ssh2 [
Jun 15 08:44:37 CT100 sshd[19273]: Disconnecting: Too many authentication failures [preauth]
Jun 15 08:44:37 CT100 sshd[19273]: PAM 5 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=218.92.0.173
Jun 15 08:44:37 CT100 sshd[19273]: PAM service(sshd) ignoring max retries; 6 > 3
Jun 15 08:44:44 CT100 sshd[19290]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=218.
Jun 15 08:44:46 CT100 sshd[19290]: Failed password for root from 218.92.0.173 port 31571 ssh2
Jun 15 08:44:47 CT100 sshd[19290]: Received disconnect from 218.92.0.173 port 31571:11: [preauth]
Jun 15 08:44:47 CT100 sshd[19290]: Disconnected from 218.92.0.173 port 31571 [preauth]
Jun 15 08:45:01 CT100 CRON[19301]: pam_unix(cron:session): session opened for user root by (uid=0)
Jun 15 08:45:01 CT100 CRON[19302]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Jun 15 08:45:01 CT100 CRON[19301]: pam_unix(cron:session): session closed for user root
lines 1114-1152/1152 (END)
364
As I said before, it does look like a permissions issue to me (but I know nothing about Proxmox). I assume it has failed to create the directory /var/run/freeswitch.
I believe the FreeSwitch startup process needs to start as root in order to execute things like /bin/mkdir -p /var/run/freeswitch and then drop its privileges to the www-data user specified by the -u on the command line.
Is there any more useful information written in the freeswitch log? (Assuming it has managed to get as far as creating a log file.)
Andyd358
243
UK
Ok I think the Promox install is fubar somehow Ive just done a fresh install on a VPS using proxmox and its worked fine by the look of it. Just need to test with a sip trunk and a phone
Andyd358
243
UK
Ive checked persmissions for the freeswitch directory (nothing in the directory from what i can see)
drwxrwx--- 2 www-data www-data 40 Jun 15 09:54 freeswitch
Feb 18, 2017
I was creating privileged containers, and Freeswitch would not install properly. Secondly it wouldn't sync time, so then I had to allow nesting.
HTH
Reactions: Andyd358
