FusionFBX sip server not connecting from xlite
Murshed
Hello!
I have installed fustionpbx but FusionFBX sip server not connecting from xlite. showing error "problem at SIP server (SIP error : 408), try again"
thanks
Murshed
Hi , Thanks for your reply
There is no log showing in fs_cli.
FusionPBX server IP: 192.168.137.2
Clinet IP (windows with X-lte) : 192.168.137.1
Here is tcpdump log when i trying to connect fusionpbx server from x-lite:
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on enp0s3, link-type EN10MB (Ethernet), capture size 262144 bytes
11:27:08.115991 IP 192.168.137.1.54294 > localhost.localdomain.sip: SIP: REGISTER sip:192.168.137.2 SIP/2.0
11:27:08.116131 IP localhost.localdomain > 192.168.137.1: ICMP localhost.localdomain udp port sip unreachable, length 556
11:27:08.116339 IP 192.168.137.1.54294 > localhost.localdomain.sip: SIP: REGISTER sip:192.168.137.2 SIP/2.0
11:27:08.116395 IP localhost.localdomain > 192.168.137.1: ICMP localhost.localdomain udp port sip unreachable, length 556
11:27:08.116584 IP 192.168.137.1.54294 > localhost.localdomain.sip: SIP: REGISTER sip:192.168.137.2 SIP/2.0
11:27:08.116633 IP localhost.localdomain > 192.168.137.1: ICMP localhost.localdomain udp port sip unreachable, length 556
11:27:08.116824 IP 192.168.137.1.54294 > localhost.localdomain.sip: SIP: REGISTER sip:192.168.137.2 SIP/2.0
11:27:08.116875 IP localhost.localdomain > 192.168.137.1: ICMP localhost.localdomain udp port sip unreachable, length 556
11:27:08.128086 IP 192.168.137.1.54294 > localhost.localdomain.sip: SIP: REGISTER sip:192.168.137.2 SIP/2.0
11:27:08.128182 IP localhost.localdomain > 192.168.137.1: ICMP localhost.localdomain udp port sip unreachable, length 556
11:27:08.128425 IP 192.168.137.1.54294 > localhost.localdomain.sip: SIP: REGISTER sip:192.168.137.2 SIP/2.0
11:27:08.128479 IP localhost.localdomain > 192.168.137.1: ICMP localhost.localdomain udp port sip unreachable, length 556
11:27:08.128693 IP 192.168.137.1.54294 > localhost.localdomain.sip: SIP: REGISTER sip:192.168.137.2 SIP/2.0
11:27:08.129562 IP 192.168.137.1.54294 > localhost.localdomain.sip: SIP: REGISTER sip:192.168.137.2 SIP/2.0
11:27:08.494788 IP6 gateway > ff02::1: ICMP6, router advertisement, length 32
11:27:08.602073 IP 192.168.137.1.54294 > localhost.localdomain.sip: SIP: REGISTER sip:192.168.137.2 SIP/2.0
11:27:08.602150 IP 192.168.137.1.54294 > localhost.localdomain.sip: SIP: REGISTER sip:192.168.137.2 SIP/2.0
11:27:08.602171 IP 192.168.137.1.54294 > localhost.localdomain.sip: SIP: REGISTER sip:192.168.137.2 SIP/2.0
11:27:08.602188 IP 192.168.137.1.54294 > localhost.localdomain.sip: SIP: REGISTER sip:192.168.137.2 SIP/2.0
11:27:08.618432 IP 192.168.137.1.54294 > localhost.localdomain.sip: SIP: REGISTER sip:192.168.137.2 SIP/2.0
11:27:08.618499 IP 192.168.137.1.54294 > localhost.localdomain.sip: SIP: REGISTER sip:192.168.137.2 SIP/2.0
11:27:08.618518 IP 192.168.137.1.54294 > localhost.localdomain.sip: SIP: REGISTER sip:192.168.137.2 SIP/2.0
11:27:08.618535 IP 192.168.137.1.54294 > localhost.localdomain.sip: SIP: REGISTER sip:192.168.137.2 SIP/2.0
11:27:09.604726 IP 192.168.137.1.54294 > localhost.localdomain.sip: SIP: REGISTER sip:192.168.137.2 SIP/2.0
11:27:09.604876 IP localhost.localdomain > 192.168.137.1: ICMP localhost.localdomain udp port sip unreachable, length 556
11:27:09.605212 IP 192.168.137.1.54294 > localhost.localdomain.sip: SIP: REGISTER sip:192.168.137.2 SIP/2.0
11:27:09.605276 IP 192.168.137.1.54294 > localhost.localdomain.sip: SIP: REGISTER sip:192.168.137.2 SIP/2.0
11:27:09.605314 IP 192.168.137.1.54294 > localhost.localdomain.sip: SIP: REGISTER sip:192.168.137.2 SIP/2.0
11:27:09.618226 IP 192.168.137.1.54294 > localhost.localdomain.sip: SIP: REGISTER sip:192.168.137.2 SIP/2.0
11:27:09.618319 IP 192.168.137.1.54294 > localhost.localdomain.sip: SIP: REGISTER sip:192.168.137.2 SIP/2.0
11:27:09.618348 IP 192.168.137.1.54294 > localhost.localdomain.sip: SIP: REGISTER sip:192.168.137.2 SIP/2.0
11:27:09.618372 IP 192.168.137.1.54294 > localhost.localdomain.sip: SIP: REGISTER sip:192.168.137.2 SIP/2.0
11:27:11.603270 IP 192.168.137.1.54294 > localhost.localdomain.sip: SIP: REGISTER sip:192.168.137.2 SIP/2.0
11:27:11.603362 IP localhost.localdomain > 192.168.137.1: ICMP localhost.localdomain udp port sip unreachable, length 556
11:27:11.603517 IP 192.168.137.1.54294 > localhost.localdomain.sip: SIP: REGISTER sip:192.168.137.2 SIP/2.0
11:27:11.603548 IP localhost.localdomain > 192.168.137.1: ICMP localhost.localdomain udp port sip unreachable, length 556
11:27:11.603679 IP 192.168.137.1.54294 > localhost.localdomain.sip: SIP: REGISTER sip:192.168.137.2 SIP/2.0
11:27:11.603699 IP 192.168.137.1.54294 > localhost.localdomain.sip: SIP: REGISTER sip:192.168.137.2 SIP/2.0
11:27:11.618302 IP 192.168.137.1.54294 > localhost.localdomain.sip: SIP: REGISTER sip:192.168.137.2 SIP/2.0
11:27:11.618373 IP 192.168.137.1.54294 > localhost.localdomain.sip: SIP: REGISTER sip:192.168.137.2 SIP/2.0
11:27:11.618390 IP 192.168.137.1.54294 > localhost.localdomain.sip: SIP: REGISTER sip:192.168.137.2 SIP/2.0
11:27:11.618405 IP 192.168.137.1.54294 > localhost.localdomain.sip: SIP: REGISTER sip:192.168.137.2 SIP/2.0
11:27:12.994742 ARP, Request who-has localhost.localdomain (08:00:27:b4:ab:5b (oui Unknown)) tell 192.168.137.1, length 46
11:27:12.994769 ARP, Reply localhost.localdomain is-at 08:00:27:b4:ab:5b (oui Unknown), length 28
11:27:15.603585 IP 192.168.137.1.54294 > localhost.localdomain.sip: SIP: REGISTER sip:192.168.137.2 SIP/2.0
11:27:15.603722 IP localhost.localdomain > 192.168.137.1: ICMP localhost.localdomain udp port sip unreachable, length 556
11:27:15.603964 IP 192.168.137.1.54294 > localhost.localdomain.sip: SIP: REGISTER sip:192.168.137.2 SIP/2.0
11:27:15.604022 IP localhost.localdomain > 192.168.137.1: ICMP localhost.localdomain udp port sip unreachable, length 556
11:27:15.604235 IP 192.168.137.1.54294 > localhost.localdomain.sip: SIP: REGISTER sip:192.168.137.2 SIP/2.0
11:27:15.604283 IP localhost.localdomain > 192.168.137.1: ICMP localhost.localdomain udp port sip unreachable, length 556
11:27:15.604495 IP 192.168.137.1.54294 > localhost.localdomain.sip: SIP: REGISTER sip:192.168.137.2 SIP/2.0
11:27:15.604541 IP localhost.localdomain > 192.168.137.1: ICMP localhost.localdomain udp port sip unreachable, length 556
11:27:15.617951 IP 192.168.137.1.54294 > localhost.localdomain.sip: SIP: REGISTER sip:192.168.137.2 SIP/2.0
11:27:15.618029 IP 192.168.137.1.54294 > localhost.localdomain.sip: SIP: REGISTER sip:192.168.137.2 SIP/2.0
11:27:15.618056 IP 192.168.137.1.54294 > localhost.localdomain.sip: SIP: REGISTER sip:192.168.137.2 SIP/2.0
11:27:15.618079 IP 192.168.137.1.54294 > localhost.localdomain.sip: SIP: REGISTER sip:192.168.137.2 SIP/2.0
11:27:19.635628 IP 192.168.137.1.54294 > localhost.localdomain.sip: SIP: REGISTER sip:192.168.137.2 SIP/2.0
11:27:19.635752 IP localhost.localdomain > 192.168.137.1: ICMP localhost.localdomain udp port sip unreachable, length 556
11:27:19.636017 IP 192.168.137.1.54294 > localhost.localdomain.sip: SIP: REGISTER sip:192.168.137.2 SIP/2.0
11:27:19.636075 IP localhost.localdomain > 192.168.137.1: ICMP localhost.localdomain udp port sip unreachable, length 556
11:27:19.636294 IP 192.168.137.1.54294 > localhost.localdomain.sip: SIP: REGISTER sip:192.168.137.2 SIP/2.0
11:27:19.636354 IP localhost.localdomain > 192.168.137.1: ICMP localhost.localdomain udp port sip unreachable, length 556
11:27:19.636576 IP 192.168.137.1.54294 > localhost.localdomain.sip: SIP: REGISTER sip:192.168.137.2 SIP/2.0
11:27:19.636635 IP localhost.localdomain > 192.168.137.1: ICMP localhost.localdomain udp port sip unreachable, length 556
11:27:19.636856 IP 192.168.137.1.54294 > localhost.localdomain.sip: SIP: REGISTER sip:192.168.137.2 SIP/2.0
11:27:19.637789 IP 192.168.137.1.54294 > localhost.localdomain.sip: SIP: REGISTER sip:192.168.137.2 SIP/2.0
11:27:19.637824 IP 192.168.137.1.54294 > localhost.localdomain.sip: SIP: REGISTER sip:192.168.137.2 SIP/2.0
11:27:19.637849 IP 192.168.137.1.54294 > localhost.localdomain.sip: SIP: REGISTER sip:192.168.137.2 SIP/2.0
11:27:20.622350 ARP, Request who-has 192.168.137.1 tell localhost.localdomain, length 28
11:27:20.624167 ARP, Reply 192.168.137.1 is-at 0a:00:27:00:00:14 (oui Unknown), length 46
11:27:23.602267 IP 192.168.137.1.54294 > localhost.localdomain.sip: SIP: REGISTER sip:192.168.137.2 SIP/2.0
11:27:23.602401 IP localhost.localdomain > 192.168.137.1: ICMP localhost.localdomain udp port sip unreachable, length 556
11:27:23.602635 IP 192.168.137.1.54294 > localhost.localdomain.sip: SIP: REGISTER sip:192.168.137.2 SIP/2.0
11:27:23.602683 IP localhost.localdomain > 192.168.137.1: ICMP localhost.localdomain udp port sip unreachable, length 556
11:27:23.602891 IP 192.168.137.1.54294 > localhost.localdomain.sip: SIP: REGISTER sip:192.168.137.2 SIP/2.0
11:27:23.602934 IP localhost.localdomain > 192.168.137.1: ICMP localhost.localdomain udp port sip unreachable, length 556
11:27:23.603143 IP 192.168.137.1.54294 > localhost.localdomain.sip: SIP: REGISTER sip:192.168.137.2 SIP/2.0
11:27:23.603186 IP localhost.localdomain > 192.168.137.1: ICMP localhost.localdomain udp port sip unreachable, length 556
11:27:23.618780 IP 192.168.137.1.54294 > localhost.localdomain.sip: SIP: REGISTER sip:192.168.137.2 SIP/2.0
11:27:23.618875 IP 192.168.137.1.54294 > localhost.localdomain.sip: SIP: REGISTER sip:192.168.137.2 SIP/2.0
11:27:23.618904 IP 192.168.137.1.54294 > localhost.localdomain.sip: SIP: REGISTER sip:192.168.137.2 SIP/2.0
11:27:23.618927 IP 192.168.137.1.54294 > localhost.localdomain.sip: SIP: REGISTER sip:192.168.137.2 SIP/2.0
11:27:27.602929 IP 192.168.137.1.54294 > localhost.localdomain.sip: SIP: REGISTER sip:192.168.137.2 SIP/2.0
11:27:27.603974 IP localhost.localdomain > 192.168.137.1: ICMP localhost.localdomain udp port sip unreachable, length 556
11:27:27.604214 IP 192.168.137.1.54294 > localhost.localdomain.sip: SIP: REGISTER sip:192.168.137.2 SIP/2.0
11:27:27.604280 IP localhost.localdomain > 192.168.137.1: ICMP localhost.localdomain udp port sip unreachable, length 556
11:27:27.604496 IP 192.168.137.1.54294 > localhost.localdomain.sip: SIP: REGISTER sip:192.168.137.2 SIP/2.0
11:27:27.609374 IP localhost.localdomain > 192.168.137.1: ICMP localhost.localdomain udp port sip unreachable, length 556
11:27:27.609631 IP 192.168.137.1.54294 > localhost.localdomain.sip: SIP: REGISTER sip:192.168.137.2 SIP/2.0
11:27:27.609711 IP localhost.localdomain > 192.168.137.1: ICMP localhost.localdomain udp port sip unreachable, length 556
11:27:27.623811 IP 192.168.137.1.54294 > localhost.localdomain.sip: SIP: REGISTER sip:192.168.137.2 SIP/2.0
11:27:27.623902 IP 192.168.137.1.54294 > localhost.localdomain.sip: SIP: REGISTER sip:192.168.137.2 SIP/2.0
11:27:27.623934 IP 192.168.137.1.54294 > localhost.localdomain.sip: SIP: REGISTER sip:192.168.137.2 SIP/2.0
11:27:27.623961 IP 192.168.137.1.54294 > localhost.localdomain.sip: SIP: REGISTER sip:192.168.137.2 SIP/2.0
I will give you server access can you pls help me to configure.
I'd guess you have probably got yourself banned, have a look with: iptables -L
