FusionPBX Installation Issue Debian 9
John
97
When I install FusionPBX 4.4 on Debian 9 I receive two errors:
1) 11 main 5432 down postgres /var/lib/postgresql/11/main /var/log/postgresql/postgresql-11-main.log
I found the following answer to it, and can you check if it is correct?
https://stackoverflow.com/questions...t-connect-to-server-no-such-file-or-directory
2) Failed to restart php7.1-fpm.service: Unit php7.1-fpm.service not found.
I guess it is because php7.1 is not installed. Is it necessary? Do you suggest me to install php7.1 to get rid of this error?
If you want to replicate the error, I don't mind giving you a fresh install Debian 9 Server for demo.
Thanks,
John
John
97
For some reason I did not get a notification after your response. Sorry!
It seems it is working, but the errors makes me feel nerves. What if they create some issues that I have not tested. What do you think?
John
97
Thank you very much. BTW, is there a way that I can contribute to this website? Maybe making a donation or answering some questions?
