Grandstream digit plan
roger_roger
198
19
I need help with 2 things please.
1) I need the digit map for a Grandstream phone that sends the calls after the 10th digit is pressed
2) I need the variable name to set in Fusion provisioning for that digit map so the phones will down load it
196
Default settings>Provision> grandstream_dial_plan
For North America with 10 digit local dialing, here's the dialplan to use...
{\p\a\r\k\+*x+ | [349]11 | [2-9]xx[2-9]xxxxxx | 1[2-9]xx[2-9]xxxxxx | 011x+ }
First part will allows "park+<parkslot>" for programmed park BLF keys. (can be omitted if not using parking slot status keys)
311, 411, 911 will dial immediately after the 3rd digit
2125551212 will dial immediately after the 10th digit
12125551212 will dial immediately after the 11th digit
International calls starting with 011 will dial after the timeout or you press the send key. (Can be omitted to disable international dialing)
196
A more complete dial plan if you want to allow feature codes to be dialed should include the defaults *x+ and x+ to allow everything else.
{\p\a\r\k\+*x+ | [349]11 | [2-9]xx[2-9]xxxxxx | 1[2-9]xx[2-9]xxxxxx | 011x+ | *x+ | x+ }
Another example for a customer with 10xx extension numbers:
{10xx | \p\a\r\k\+*x+ | [349]11 | [2-9]xx[2-9]xxxxxx | 1[2-9]xx[2-9]xxxxxx | 011x+ | *x+ | x+ }
roger_roger
198
19
Thank you so much! Do you know the variable name for this so the phones will pick up this dial plan via provisioning?
As an example, in settings for a Polycom, I use polycom_digimap with the dial plan as the value
