Help with Twilio SIP Trunk on FusionPBX 4.5
agile
Hi Guys I am struggling to setup Twilio trunk configuration on fusionpbx any help will be greatly appreciated.
I have setup Gateway as following
Gateway: Twilio
Username; usernamefortwilio
Password: passwdfortwilio
From User: left empty
From Domain: left empty
Proxy: something.pstn.twilio.com
Realm: left empty
Expire Seconds: 800
Register: True
Retry Seconds: 30
Context: public
Hostname: left empty
Enabled: False
Description: left empty
Any idea what I did wrong?
I can share screenshots of inbound and outbound too.
Appreciate if anyone can give some guidance.
Acer76e
Lakeland, FL, USA
www.callbreezy.com
Good morning, a few things that I can tell you seem incorrect that you'll want to check:
1. "From User" - this should be your associated phone number within Twilio, example 15559231234 (include the 1, don't include any + or dashes)
2. Enabled: This should be set to TRUE.
Try those two updates, and then see if you're still having issues with getting a REGED status.
Reactions: agile
UCtech
12
If you haven't already you'll need to set up the inbound Twilio gateways from these IP addresses:
There are 4 east coast and 4 west coast. Calls can come through any of them, so you need to set them all up (and/or International as well). Twilio has great redundancy but this requires a bit more work to set up. As for each field:
Gateway: Descriptive Name -- might want to name each IP gateway with something that helps you to identify/differentiate each, like TwilOregon1
User Name & Password: Depends on how you set up your Twilio -- if you use no auth but your IP's then put bogus info in each field (I think Fusion will not let you leave them blank). Otherwise, put the auth that Twilio gave you in the Trunk settings.
Proxy: IP address from the link above corresponding to which Twilio link you are setting up.
Register: False if not using auth, True if yes, depending on your Twilio settings
Enabled: True
That's all for inbound normally.
Outbound Gateway setup:
Same as above except for the Proxy. Use DomainNameThatTwilioProvides.pstn.twilio.com
Hope that helps
Reactions: agile
agile
Thanks for your help guys. Finally, I got this to work I will post all the screenshots to make it easy for others soon.
