How To Test Fax Machine of HP and Canon in (2019)
If you want to check if a fax machine is working, you generally want to make sure that it can send and receive faxes.
Here I am going to guide you with how to get fax number and start sending and receiving faxes for better communication.
How to Get a Toll Free Fax Number
Here, I am going to tell you about the process of getting a toll free fax number. Getting a toll free fax number is little complicated than the local fax number. In order to get this, there are two ways –
  1. a) Ask your local phone provider to get you a toll-free fax number.
This option is used by a majority of the people. Here, your toll-free number is going to complement your existing local fax number.
  1. b) By using a toll-free forwarding number. It will redirect you to your existing local fax number.
How to get a local Fax number
If your business has a local telephone number, then adding a fax number to your account should be very easy and simple. Simply call your telephone service provider and ask for an additional fax number or just look at their fax plans online.
If you run a business on sending and receiving a lot of faxes per day, then paying for an additional fax number is a good idea.
How to get an online fax number
If you have already had a fax number and want to switch to email faxing, then you will be easily switching your network by keeping the same number.
However, if you are signing up for an online fax service with no number, then it works fine. In fact, a majority of the online fax providers prefer setting up online faxing on a new number.
Here is step by step guide-
Step 1) Research for the best online fax providers
Step2) Compare sign-up incentives
Step3) After finalizing the service provider and their plans go for Sign-up
Step4) Test your number
Whether you already have a fax number, or you are creating one for the first time, online faxing remains the easiest and preferred way to fax in current time.
HP Test fax Number, Canon Fax Number, Brother Fax Number
If you have decided to test your fax machine, popular companies like HP, Canon, and Brother provides the facility to test your fax.
This can be done with the help of knowing the numbers of HP, Canon, and Brother.
Here below are the numbers –
HP – 1-888-HP-FAX-ME
Canon – 1-855-FX-CANON
Brother – 1-877-268-9575
Read More about These Topic on Details
Test Fax Setup Process with the HP Fax Test service
How to test Fax Free
How to send fax online?
Overview the process of sending fax online:
How to find your fax machine Number?
Read Complete Post Here about How To Send Test Fax From HP
