Inbound and outbound calls failing ( Rejected)
agile
27
Hi All, I am new to this forum and new to FusionPBX have good experience of asterisk / freepbx. I want to try out Fusion PBX for the multitenant functionality.
I had no problems in installing and getting the extensions working thanks to great documentation and some help from good people around the world like you.
Unfortunately, I am now stuck where I am trying to get inbound and outbound calls setup.
1. Gateway setup successfully with GO-Trunk ( this worked fine with FreePBX)
2. inbound calls get error screenshot from GO-Tunk with sip trace attached for reference.
3. Outbound also gives an error message
Note I have $2 on the GO-Trunk account so it's not related to no balance.
I will appreciate if someone can assist.
( I have got this working only with INBOUND calls using SIPGATE UK today but Outbound was still not working, hence why I decided to try Go-Trunk as a sip-trunk provider)
0.00000[F1] —————————— INVITE —————————>
sip:82942@amn.st.ssl7.net
0.00005[F2] <——————— 100 Trying ————————
0.00009[F3] <————— 404 Not Found ——————
# [F1] U 134.19.166.164:5060 -> 109.233.115.107:5060 time (from start) 0.00000 (from previous frame) 0.00000INVITE sip:82942@amn.st.ssl7.net SIP/2.0
Via: SIP/2.0/UDP 134.19.166.164:5060;branch=z9hG4bK65409c0c
Max-Forwards: 70
From: <sip:447714561552@eu.st.ssl7.net>;tag=as50c51f5b
To: <sip:82942@amn.st.ssl7.net>
Contact: <sip:447714561552@134.19.166.164:5060>
Call-ID: 30837792209ad9455b416117696d8c15@eu.st.ssl7.net
CSeq: 102 INVITE
User-Agent: Media GW uk024
Date: Tue, 27 Oct 2020 02:14:40 GMT
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, PUBLISH
Supported: replaces
X-E164: 19024184571
X-CID: 1e713f0d9a33955c0ad1d0db86ae53a79ff40800
Content-Type: application/sdp
Content-Length: 436
v=0
o=root 1308363502 1308363502 IN IP4 134.19.166.164
s=Media GW uk024
c=IN IP4 134.19.166.164
t=0 0
m=audio 14620 RTP/AVP 8 0 3 4 111 110 9 101
a=rtpmap:8 PCMA/8000
a=rtpmap:0 PCMU/8000
a=rtpmap:3 GSM/8000
a=rtpmap:4 G723/8000
a=fmtp:4 annexa=no
a=rtpmap:111 G726-32/8000
a=rtpmap:110 speex/8000
a=rtpmap:9 G722/8000
a=fmtp:101 0-16
a=silenceSupp:eek:ff - - - -
a=ptime:20
a=sendrecv
# [F2] U 109.233.115.107:5060 -> 134.19.166.164:5060 time (from start) 0.00005 (from previous frame) 0.00005SIP/2.0 100 Trying
CSeq: 102 INVITE
Server: SIP Trunk Proxy 2
Content-Length: 0
# [F3] U 109.233.115.107:5060 -> 134.19.166.164:5060 time (from start) 0.00009 (from previous frame) 0.00004SIP/2.0 404 Not Found
To: <sip:82942@amn.st.ssl7.net>;tag=a91e.d3d10df25be17433e6b4452235afa35d
CSeq: 102 INVITE
Content-Length: 0
sngrep details attached.
and fs_cli trace given below
2020-10-27 02:07:27.328647 [WARNING] sofia_reg.c:1793 SIP auth challenge (INVITE) on sofia profile 'internal' for [0019024184571@agilehive.ddns.me] from ip 82.132.185.23
2020-10-27 02:07:27.328647 [DEBUG] switch_core_state_machine.c:604 (sofia/internal/3001@agilehive.ddns.me) State NEW
2020-10-27 02:07:27.508618 [DEBUG] sofia.c:2544 Re-attaching to session 29613574-17f9-11eb-8fc3-6f08f3e45e43
2020-10-27 02:07:27.508618 [DEBUG] sofia.c:10255 sofia/internal/3001@agilehive.ddns.me receiving invite from 82.132.185.23:18078 version: 1.10.2 -release 64bit
2020-10-27 02:07:27.508618 [DEBUG] sofia.c:10349 verifying acl "domains" for ip/port 82.132.185.23:0.
2020-10-27 02:07:27.528615 [DEBUG] sofia.c:7301 Channel sofia/internal/3001@agilehive.ddns.me entering state [received][100]
2020-10-27 02:07:27.528615 [DEBUG] sofia.c:7311 Remote SDP:
v=0
o=3001 8000 8000 IN IP4 82.132.185.23
s=SIP Call
c=IN IP4 82.132.185.23
t=0 0
m=audio 21370 RTP/AVP 0 8 101
a=fmtp:101 0-15
a=rtcp:21371 IN IP4 82.132.185.23
a=ptime:20
2020-10-27 02:07:27.528615 [DEBUG] switch_core_media.c:5592 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[G722:9:8000:20:64000:1]
2020-10-27 02:07:27.528615 [DEBUG] switch_core_media.c:5592 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[PCMU:0:8000:20:64000:1]
2020-10-27 02:07:27.528615 [DEBUG] switch_core_media.c:5647 Audio Codec Compare [PCMU:0:8000:20:64000:1] ++++ is saved as a match
2020-10-27 02:07:27.528615 [DEBUG] switch_core_media.c:5592 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[PCMA:8:8000:20:64000:1]
2020-10-27 02:07:27.528615 [DEBUG] switch_core_media.c:5592 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[G722:9:8000:20:64000:1]
2020-10-27 02:07:27.528615 [DEBUG] switch_core_media.c:5592 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[PCMU:0:8000:20:64000:1]
2020-10-27 02:07:27.528615 [DEBUG] switch_core_media.c:5592 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[PCMA:8:8000:20:64000:1]
2020-10-27 02:07:27.528615 [DEBUG] switch_core_media.c:5647 Audio Codec Compare [PCMA:8:8000:20:64000:1] ++++ is saved as a match
2020-10-27 02:07:27.528615 [DEBUG] switch_core_media.c:5508 Set telephone-event payload to 101@8000
2020-10-27 02:07:27.528615 [DEBUG] switch_core_media.c:3837 Set Codec sofia/internal/3001@agilehive.ddns.me PCMU/8000 20 ms 160 samples 64000 bits 1 channels
2020-10-27 02:07:27.528615 [DEBUG] switch_core_codec.c:111 sofia/internal/3001@agilehive.ddns.me Original read codec set to PCMU:0
2020-10-27 02:07:27.528615 [DEBUG] switch_core_media.c:5851 Set telephone-event payload to 101@8000
2020-10-27 02:07:27.528615 [DEBUG] switch_core_media.c:5909 sofia/internal/3001@agilehive.ddns.me Set 2833 dtmf send payload to 101 recv payload to 101
2020-10-27 02:07:27.528615 [DEBUG] sofia.c:7735 (sofia/internal/3001@agilehive.ddns.me) State Change CS_NEW -> CS_INIT
2020-10-27 02:07:27.528615 [DEBUG] switch_core_state_machine.c:585 (sofia/internal/3001@agilehive.ddns.me) Running State Change CS_INIT (Cur 1 Tot 946)
2020-10-27 02:07:27.528615 [DEBUG] switch_core_state_machine.c:628 (sofia/internal/3001@agilehive.ddns.me) State INIT
2020-10-27 02:07:27.528615 [DEBUG] mod_sofia.c:93 sofia/internal/3001@agilehive.ddns.me SOFIA INIT
2020-10-27 02:07:27.528615 [DEBUG] switch_core_state_machine.c:40 sofia/internal/3001@agilehive.ddns.me Standard INIT
2020-10-27 02:07:27.528615 [DEBUG] switch_core_state_machine.c:48 (sofia/internal/3001@agilehive.ddns.me) State Change CS_INIT -> CS_ROUTING
2020-10-27 02:07:27.528615 [DEBUG] switch_core_state_machine.c:628 (sofia/internal/3001@agilehive.ddns.me) State INIT going to sleep
2020-10-27 02:07:27.528615 [DEBUG] switch_core_state_machine.c:585 (sofia/internal/3001@agilehive.ddns.me) Running State Change CS_ROUTING (Cur 1 Tot 946)
2020-10-27 02:07:27.528615 [DEBUG] switch_channel.c:2332 (sofia/internal/3001@agilehive.ddns.me) Callstate Change DOWN -> RINGING
2020-10-27 02:07:27.528615 [DEBUG] switch_core_state_machine.c:644 (sofia/internal/3001@agilehive.ddns.me) State ROUTING
2020-10-27 02:07:27.528615 [DEBUG] mod_sofia.c:154 sofia/internal/3001@agilehive.ddns.me SOFIA ROUTING
2020-10-27 02:07:27.528615 [DEBUG] switch_core_state_machine.c:236 sofia/internal/3001@agilehive.ddns.me Standard ROUTING
2020-10-27 02:07:27.528615 [INFO] mod_dialplan_xml.c:637 Processing 3001 <3001>->0019024184571 in context agilehive.ddns.me
Dialplan: sofia/internal/3001@agilehive.ddns.me parsing [agilehive.ddns.me->user_exists] continue=true
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (FAIL) [user_exists] ${loopback_leg}() =~ /^B$/ break=never
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (PASS) [user_exists] () =~ // break=on-false
Dialplan: sofia/internal/3001@agilehive.ddns.me Action set(user_exists=${user_exists id ${destination_number} ${domain_name}}) INLINE
EXECUTE [depth=0] sofia/internal/3001@agilehive.ddns.me set(user_exists=false)
2020-10-27 02:07:27.548611 [DEBUG] mod_dptools.c:1672 SET sofia/internal/3001@agilehive.ddns.me [user_exists]=[false]
Dialplan: sofia/internal/3001@agilehive.ddns.me Action set(from_user_exists=${user_exists id ${sip_from_user} ${sip_from_host}}) INLINE
EXECUTE [depth=0] sofia/internal/3001@agilehive.ddns.me set(from_user_exists=true)
2020-10-27 02:07:27.548611 [DEBUG] mod_dptools.c:1672 SET sofia/internal/3001@agilehive.ddns.me [from_user_exists]=[true]
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (FAIL) [user_exists] ${user_exists}(false) =~ /^true$/ break=on-false
Dialplan: sofia/internal/3001@agilehive.ddns.me parsing [agilehive.ddns.me->caller-details] continue=true
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (PASS) [caller-details] ${caller_destination}() =~ /^$/ break=never
Dialplan: sofia/internal/3001@agilehive.ddns.me Action set(caller_destination=${destination_number}) INLINE
EXECUTE [depth=0] sofia/internal/3001@agilehive.ddns.me set(caller_destination=0019024184571)
2020-10-27 02:07:27.548611 [DEBUG] mod_dptools.c:1672 SET sofia/internal/3001@agilehive.ddns.me [caller_destination]=[0019024184571]
Dialplan: sofia/internal/3001@agilehive.ddns.me Action set(caller_id_name=${caller_id_name}) INLINE
EXECUTE [depth=0] sofia/internal/3001@agilehive.ddns.me set(caller_id_name=3001)
2020-10-27 02:07:27.548611 [DEBUG] mod_dptools.c:1672 SET sofia/internal/3001@agilehive.ddns.me [caller_id_name]=[3001]
Dialplan: sofia/internal/3001@agilehive.ddns.me Action set(caller_id_number=${caller_id_number})
Dialplan: sofia/internal/3001@agilehive.ddns.me parsing [agilehive.ddns.me->call-direction] continue=true
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (FAIL) [call-direction] ${call_direction}() =~ /^(inbound|outbound|local)$/ break=never
Dialplan: sofia/internal/3001@agilehive.ddns.me ANTI-Action export(call_direction=local) INLINE
EXECUTE [depth=0] sofia/internal/3001@agilehive.ddns.me export(call_direction=local)
2020-10-27 02:07:27.548611 [DEBUG] switch_channel.c:1310 EXPORT (export_vars) [call_direction]=[local]
Dialplan: sofia/internal/3001@agilehive.ddns.me parsing [agilehive.ddns.me->global-variables] continue=true
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (PASS) [global-variables] () =~ // break=on-false
Dialplan: sofia/internal/3001@agilehive.ddns.me Action set(RFC2822_DATE=${strftime(%a, %d %b %Y %T %z)})
Dialplan: sofia/internal/3001@agilehive.ddns.me parsing [agilehive.ddns.me->domain-variables] continue=true
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (PASS) [domain-variables] () =~ // break=on-false
Dialplan: sofia/internal/3001@agilehive.ddns.me Action export(origination_callee_id_name=${destination_number})
Dialplan: sofia/internal/3001@agilehive.ddns.me parsing [agilehive.ddns.me->is_loopback] continue=true
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (FAIL) [is_loopback] ${is_follow_me_loopback}() =~ /true/ break=on-false
Dialplan: sofia/internal/3001@agilehive.ddns.me parsing [agilehive.ddns.me->user_record] continue=true
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (FAIL) [user_record] ${user_record}() =~ /^all$/ break=never
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (FAIL) [user_record] ${call_direction}(local) =~ /^inbound$/ break=never
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (FAIL) [user_record] ${user_record}() =~ /^inbound$/ break=never
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (FAIL) [user_record] ${call_direction}(local) =~ /^outbound$/ break=never
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (FAIL) [user_record] ${user_record}() =~ /^outbound$/ break=never
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (PASS) [user_record] ${call_direction}(local) =~ /^local$/ break=never
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (FAIL) [user_record] ${user_record}() =~ /^local$/ break=never
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
Dialplan: sofia/internal/3001@agilehive.ddns.me Action set(from_user_record=${user_data ${sip_from_user}@${sip_from_host} var user_record}) INLINE
EXECUTE [depth=0] sofia/internal/3001@agilehive.ddns.me set(from_user_record=)
2020-10-27 02:07:27.548611 [DEBUG] mod_dptools.c:1672 SET sofia/internal/3001@agilehive.ddns.me [from_user_record]=[UNDEF]
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (FAIL) [user_record] ${from_user_record}() =~ /^all$/ break=never
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (FAIL) [user_record] ${from_user_record}() =~ /^inbound$/ break=never
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (FAIL) [user_record] ${from_user_record}() =~ /^outbound$/ break=never
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (FAIL) [user_record] ${from_user_record}() =~ /^local$/ break=never
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (FAIL) [user_record] ${record_session}() =~ /^true$/ break=on-false
Dialplan: sofia/internal/3001@agilehive.ddns.me parsing [agilehive.ddns.me->redial] continue=true
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (FAIL) [redial] destination_number(0019024184571) =~ /^(redial|\*870)$/ break=on-true
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (PASS) [redial] () =~ // break=never
Dialplan: sofia/internal/3001@agilehive.ddns.me Action hash(insert/${domain_name}-last_dial/${caller_id_number}/${destination_number})
Dialplan: sofia/internal/3001@agilehive.ddns.me parsing [agilehive.ddns.me->speed_dial] continue=false
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (FAIL) [speed_dial] destination_number(0019024184571) =~ /^\*0(.*)$/ break=on-false
Dialplan: sofia/internal/3001@agilehive.ddns.me parsing [agilehive.ddns.me->default_caller_id] continue=true
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (FAIL) [default_caller_id] ${emergency_caller_id_number}(0019024184571) =~ /^$/ break=never
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (FAIL) [default_caller_id] ${outbound_caller_id_number}(0019024184571) =~ /^$/ break=never
Dialplan: sofia/internal/3001@agilehive.ddns.me parsing [agilehive.ddns.me->user_hold_music] continue=true
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (FAIL) [user_hold_music] ${hold_music}(local_stream://default) =~ /^$/ break=never
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (FAIL) [user_hold_music] ${user_exists}(false) =~ /true/ break=on-false
Dialplan: sofia/internal/3001@agilehive.ddns.me parsing [agilehive.ddns.me->Go_Trunk.1d10] continue=false
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (PASS) [Go_Trunk.1d10] ${user_exists}(false) =~ /false/ break=on-false
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (FAIL) [Go_Trunk.1d10] destination_number(0019024184571) =~ /^\+?1?(\d{10})$/ break=on-false
Dialplan: sofia/internal/3001@agilehive.ddns.me parsing [agilehive.ddns.me->Sales_RingGroup] continue=
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (FAIL) [Sales_RingGroup] destination_number(0019024184571) =~ /^5050$/ break=on-false
Dialplan: sofia/internal/3001@agilehive.ddns.me parsing [agilehive.ddns.me->Welcome _IVR] continue=false
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (FAIL) [Welcome _IVR] destination_number(0019024184571) =~ /^7777$/ break=on-false
Dialplan: sofia/internal/3001@agilehive.ddns.me parsing [agilehive.ddns.me->agent_status] continue=false
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (FAIL) [agent_status] destination_number(0019024184571) =~ /^\*22$/ break=never
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (FAIL) [agent_status] destination_number(0019024184571) =~ /^(agent\+)(.*)$/ break=on-false
Dialplan: sofia/internal/3001@agilehive.ddns.me parsing [agilehive.ddns.me->agent_status_id] continue=false
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (FAIL) [agent_status_id] destination_number(0019024184571) =~ /^\*23$/ break=on-false
Dialplan: sofia/internal/3001@agilehive.ddns.me parsing [agilehive.ddns.me->group-intercept] continue=false
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (FAIL) [group-intercept] destination_number(0019024184571) =~ /^\*8$/ break=on-false
Dialplan: sofia/internal/3001@agilehive.ddns.me parsing [agilehive.ddns.me->page-extension] continue=false
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (FAIL) [page-extension] destination_number(0019024184571) =~ /^\*8(\d{2,7})$/ break=on-false
Dialplan: sofia/internal/3001@agilehive.ddns.me parsing [agilehive.ddns.me->eavesdrop] continue=false
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (FAIL) [eavesdrop] destination_number(0019024184571) =~ /^\*33(\d{2,7})$/ break=on-false
Dialplan: sofia/internal/3001@agilehive.ddns.me parsing [agilehive.ddns.me->call_privacy] continue=false
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (FAIL) [call_privacy] destination_number(0019024184571) =~ /^\*67(\d+)$/ break=on-false
Dialplan: sofia/internal/3001@agilehive.ddns.me parsing [agilehive.ddns.me->call_return] continue=false
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (FAIL) [call_return] destination_number(0019024184571) =~ /^\*69$/ break=on-false
Dialplan: sofia/internal/3001@agilehive.ddns.me parsing [agilehive.ddns.me->extension_queue] continue=
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (FAIL) [extension_queue] destination_number(0019024184571) =~ /^\*800(.*)$/ break=on-false
Dialplan: sofia/internal/3001@agilehive.ddns.me parsing [agilehive.ddns.me->intercept-ext] continue=false
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (FAIL) [intercept-ext] destination_number(0019024184571) =~ /^\*\*(\d+)$/ break=on-true
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (FAIL) [intercept-ext] destination_number(0019024184571) =~ /^\*\*$/ break=on-false
Dialplan: sofia/internal/3001@agilehive.ddns.me parsing [agilehive.ddns.me->intercept-ext-polycom] continue=false
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (FAIL) [intercept-ext-polycom] destination_number(0019024184571) =~ /^\*97(\d+)$/ break=on-false
Dialplan: sofia/internal/3001@agilehive.ddns.me parsing [agilehive.ddns.me->dx] continue=false
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (FAIL) [dx] destination_number(0019024184571) =~ /^dx$/ break=on-false
Dialplan: sofia/internal/3001@agilehive.ddns.me parsing [agilehive.ddns.me->send_to_voicemail] continue=false
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (FAIL) [send_to_voicemail] destination_number(0019024184571) =~ /^\*99(\d{2,10})$/ break=on-false
Dialplan: sofia/internal/3001@agilehive.ddns.me parsing [agilehive.ddns.me->att_xfer] continue=false
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (FAIL) [att_xfer] destination_number(0019024184571) =~ /^att_xfer$/ break=on-false
Dialplan: sofia/internal/3001@agilehive.ddns.me parsing [agilehive.ddns.me->extension-to-voicemail] continue=false
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (FAIL) [extension-to-voicemail] ${user_exists}(false) =~ /^true$/ break=on-false
Dialplan: sofia/internal/3001@agilehive.ddns.me parsing [agilehive.ddns.me->vmain] continue=false
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (FAIL) [vmain] destination_number(0019024184571) =~ /^vmain$|^\*4000$|^\*98$/ break=never
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (FAIL) [vmain] destination_number(0019024184571) =~ /^(vmain$|^\*4000$|^\*98)(\d{2,12})$/ break=on-false
Dialplan: sofia/internal/3001@agilehive.ddns.me parsing [agilehive.ddns.me->xfer_vm] continue=false
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (FAIL) [xfer_vm] destination_number(0019024184571) =~ /^xfer_vm$/ break=on-false
Dialplan: sofia/internal/3001@agilehive.ddns.me parsing [agilehive.ddns.me->vmain_user] continue=false
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (FAIL) [vmain_user] destination_number(0019024184571) =~ /^\*97$/ break=on-false
Dialplan: sofia/internal/3001@agilehive.ddns.me parsing [agilehive.ddns.me->is_transfer] continue=false
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (FAIL) [is_transfer] destination_number(0019024184571) =~ /^is_transfer$/ break=on-false
Dialplan: sofia/internal/3001@agilehive.ddns.me parsing [agilehive.ddns.me->4000] continue=
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (FAIL) [4000] destination_number(0019024184571) =~ /^4000$/ break=on-false
Dialplan: sofia/internal/3001@agilehive.ddns.me parsing [agilehive.ddns.me->cf] continue=false
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (FAIL) [cf] destination_number(0019024184571) =~ /^cf$/ break=on-false
Dialplan: sofia/internal/3001@agilehive.ddns.me parsing [agilehive.ddns.me->delay_echo] continue=false
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (FAIL) [delay_echo] destination_number(0019024184571) =~ /^\*9195$/ break=on-false
Dialplan: sofia/internal/3001@agilehive.ddns.me parsing [agilehive.ddns.me->echo] continue=false
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (FAIL) [echo] destination_number(0019024184571) =~ /^\*9196$/ break=on-false
Dialplan: sofia/internal/3001@agilehive.ddns.me parsing [agilehive.ddns.me->milliwatt] continue=false
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (FAIL) [milliwatt] destination_number(0019024184571) =~ /^\*9197$/ break=on-false
Dialplan: sofia/internal/3001@agilehive.ddns.me parsing [agilehive.ddns.me->is_zrtp_secure] continue=true
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (FAIL) [is_zrtp_secure] ${zrtp_secure_media_confirmed}() =~ /^true$/ break=on-false
Dialplan: sofia/internal/3001@agilehive.ddns.me ANTI-Action eval(not_secure)
Dialplan: sofia/internal/3001@agilehive.ddns.me parsing [agilehive.ddns.me->is_secure] continue=true
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (FAIL) [is_secure] ${sip_via_protocol}(udp) =~ /tls/ break=on-false
Dialplan: sofia/internal/3001@agilehive.ddns.me parsing [agilehive.ddns.me->tone_stream] continue=false
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (FAIL) [tone_stream] destination_number(0019024184571) =~ /^\*9198$/ break=on-false
Dialplan: sofia/internal/3001@agilehive.ddns.me parsing [agilehive.ddns.me->hold_music] continue=false
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (FAIL) [hold_music] destination_number(0019024184571) =~ /^\*9664$/ break=on-false
Dialplan: sofia/internal/3001@agilehive.ddns.me parsing [agilehive.ddns.me->recordings] continue=false
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (FAIL) [recordings] destination_number(0019024184571) =~ /^\*(732)$/ break=on-false
Dialplan: sofia/internal/3001@agilehive.ddns.me parsing [agilehive.ddns.me->directory] continue=false
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (FAIL) [directory] destination_number(0019024184571) =~ /^\*411$/ break=on-false
Dialplan: sofia/internal/3001@agilehive.ddns.me parsing [agilehive.ddns.me->wake-up] continue=false
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (FAIL) [wake-up] destination_number(0019024184571) =~ /^\*(925)$/ break=on-false
Dialplan: sofia/internal/3001@agilehive.ddns.me parsing [agilehive.ddns.me->valet_park] continue=false
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (FAIL) [valet_park] destination_number(0019024184571) =~ /^(park\+)?\*(59[0-9][0-9])$/ break=never
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (FAIL) [valet_park] ${sip_h_Referred-By}() =~ /sip:(.*)@.*/ break=never
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (FAIL) [valet_park] destination_number(0019024184571) =~ /^(park\+)?\*(59[0-9][0-9])$/ break=on-false
Dialplan: sofia/internal/3001@agilehive.ddns.me parsing [agilehive.ddns.me->operator] continue=false
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (FAIL) [operator] destination_number(0019024184571) =~ /^0$|^operator$/ break=on-false
Dialplan: sofia/internal/3001@agilehive.ddns.me parsing [agilehive.ddns.me->operator-forward] continue=false
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (FAIL) [operator-forward] destination_number(0019024184571) =~ /^\*000$/ break=on-false
Dialplan: sofia/internal/3001@agilehive.ddns.me parsing [agilehive.ddns.me->do-not-disturb] continue=false
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (FAIL) [do-not-disturb] destination_number(0019024184571) =~ /^\*77$/ break=on-true
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (FAIL) [do-not-disturb] destination_number(0019024184571) =~ /^\*78$|\*363$/ break=on-true
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (FAIL) [do-not-disturb] destination_number(0019024184571) =~ /^\*79$/ break=on-true
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (FAIL) [do-not-disturb] destination_number(0019024184571) =~ /^dnd\+3001$/ break=on-true
Dialplan: sofia/internal/3001@agilehive.ddns.me parsing [agilehive.ddns.me->call_screen] continue=true
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (FAIL) [call_screen] ${call_screen_enabled}(false) =~ /^true$/ break=on-false
Dialplan: sofia/internal/3001@agilehive.ddns.me parsing [agilehive.ddns.me->call-forward] continue=false
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (FAIL) [call-forward] destination_number(0019024184571) =~ /^\*72(\d*)$/ break=on-true
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (FAIL) [call-forward] destination_number(0019024184571) =~ /^\*73$/ break=on-true
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (FAIL) [call-forward] destination_number(0019024184571) =~ /^\*74$/ break=on-true
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (FAIL) [call-forward] destination_number(0019024184571) =~ /^forward\+(\Q3001\E)(?:\/(\d+))?$/ break=on-true
Dialplan: sofia/internal/3001@agilehive.ddns.me parsing [agilehive.ddns.me->follow-me-destinations] continue=false
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (FAIL) [follow-me-destinations] ${user_exists}(false) =~ /^true$/ break=on-false
Dialplan: sofia/internal/3001@agilehive.ddns.me parsing [agilehive.ddns.me->call-forward-all] continue=
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (FAIL) [call-forward-all] ${user_exists}(false) =~ /true/ break=on-false
Dialplan: sofia/internal/3001@agilehive.ddns.me parsing [agilehive.ddns.me->call-forward-not-registered] continue=
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (FAIL) [call-forward-not-registered] ${user_exists}(false) =~ /true/ break=on-false
Dialplan: sofia/internal/3001@agilehive.ddns.me parsing [agilehive.ddns.me->follow-me] continue=false
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (FAIL) [follow-me] destination_number(0019024184571) =~ /^\*21$/ break=on-false
Dialplan: sofia/internal/3001@agilehive.ddns.me parsing [agilehive.ddns.me->clear_sip_auto_answer] continue=true
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (FAIL) [clear_sip_auto_answer] ${click_to_call}() =~ /true/ break=on-false
Dialplan: sofia/internal/3001@agilehive.ddns.me parsing [agilehive.ddns.me->talking clock date and time] continue=
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (FAIL) [talking clock date and time] destination_number(0019024184571) =~ /^\*9172$/ break=on-false
Dialplan: sofia/internal/3001@agilehive.ddns.me parsing [agilehive.ddns.me->talking clock time] continue=
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (FAIL) [talking clock time] destination_number(0019024184571) =~ /^\*9170$/ break=on-false
Dialplan: sofia/internal/3001@agilehive.ddns.me parsing [agilehive.ddns.me->talking clock date] continue=
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (FAIL) [talking clock date] destination_number(0019024184571) =~ /^\*9171$/ break=on-false
Dialplan: sofia/internal/3001@agilehive.ddns.me parsing [agilehive.ddns.me->local_extension] continue=true
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (FAIL) [local_extension] ${user_exists}(false) =~ /true/ break=on-false
Dialplan: sofia/internal/3001@agilehive.ddns.me parsing [agilehive.ddns.me->voicemail] continue=false
Dialplan: sofia/internal/3001@agilehive.ddns.me Regex (FAIL) [voicemail] ${user_exists}(false) =~ /true/ break=on-false
2020-10-27 02:07:27.548611 [DEBUG] switch_core_state_machine.c:287 (sofia/internal/3001@agilehive.ddns.me) State Change CS_ROUTING -> CS_EXECUTE
2020-10-27 02:07:27.548611 [DEBUG] switch_core_state_machine.c:644 (sofia/internal/3001@agilehive.ddns.me) State ROUTING going to sleep
2020-10-27 02:07:27.548611 [DEBUG] switch_core_state_machine.c:585 (sofia/internal/3001@agilehive.ddns.me) Running State Change CS_EXECUTE (Cur 1 Tot 946)
2020-10-27 02:07:27.548611 [DEBUG] switch_core_state_machine.c:651 (sofia/internal/3001@agilehive.ddns.me) State EXECUTE
2020-10-27 02:07:27.548611 [DEBUG] mod_sofia.c:209 sofia/internal/3001@agilehive.ddns.me SOFIA EXECUTE
2020-10-27 02:07:27.548611 [DEBUG] switch_core_state_machine.c:329 sofia/internal/3001@agilehive.ddns.me Standard EXECUTE
EXECUTE [depth=0] sofia/internal/3001@agilehive.ddns.me set(caller_id_number=3001)
2020-10-27 02:07:27.548611 [DEBUG] mod_dptools.c:1672 SET sofia/internal/3001@agilehive.ddns.me [caller_id_number]=[3001]
EXECUTE [depth=0] sofia/internal/3001@agilehive.ddns.me set(RFC2822_DATE=Tue, 27 Oct 2020 02:07:27 +0000)
2020-10-27 02:07:27.548611 [DEBUG] mod_dptools.c:1672 SET sofia/internal/3001@agilehive.ddns.me [RFC2822_DATE]=[Tue, 27 Oct 2020 02:07:27 +0000]
EXECUTE [depth=0] sofia/internal/3001@agilehive.ddns.me export(origination_callee_id_name=0019024184571)
2020-10-27 02:07:27.548611 [DEBUG] switch_channel.c:1310 EXPORT (export_vars) [origination_callee_id_name]=[0019024184571]
EXECUTE [depth=0] sofia/internal/3001@agilehive.ddns.me hash(insert/agilehive.ddns.me-last_dial/3001/0019024184571)
EXECUTE [depth=0] sofia/internal/3001@agilehive.ddns.me eval(not_secure)
2020-10-27 02:07:27.548611 [NOTICE] switch_core_state_machine.c:386 sofia/internal/3001@agilehive.ddns.me has executed the last dialplan instruction, hanging up.
2020-10-27 02:07:27.548611 [NOTICE] switch_core_state_machine.c:388 Hangup sofia/internal/3001@agilehive.ddns.me [CS_EXECUTE] [NORMAL_CLEARING]
2020-10-27 02:07:27.548611 [DEBUG] switch_core_state_machine.c:651 (sofia/internal/3001@agilehive.ddns.me) State EXECUTE going to sleep
2020-10-27 02:07:27.548611 [DEBUG] switch_core_state_machine.c:585 (sofia/internal/3001@agilehive.ddns.me) Running State Change CS_HANGUP (Cur 1 Tot 946)
2020-10-27 02:07:27.548611 [DEBUG] switch_core_state_machine.c:848 (sofia/internal/3001@agilehive.ddns.me) Callstate Change RINGING -> HANGUP
2020-10-27 02:07:27.548611 [DEBUG] switch_core_state_machine.c:850 (sofia/internal/3001@agilehive.ddns.me) State HANGUP
2020-10-27 02:07:27.548611 [DEBUG] mod_sofia.c:453 Channel sofia/internal/3001@agilehive.ddns.me hanging up, cause: NORMAL_CLEARING
2020-10-27 02:07:27.548611 [DEBUG] mod_sofia.c:598 Responding to INVITE with: 480
2020-10-27 02:07:27.548611 [DEBUG] switch_core_state_machine.c:60 sofia/internal/3001@agilehive.ddns.me Standard HANGUP, cause: NORMAL_CLEARING
2020-10-27 02:07:27.548611 [DEBUG] switch_core_state_machine.c:850 (sofia/internal/3001@agilehive.ddns.me) State HANGUP going to sleep
2020-10-27 02:07:27.548611 [DEBUG] switch_core_state_machine.c:620 (sofia/internal/3001@agilehive.ddns.me) State Change CS_HANGUP -> CS_REPORTING
2020-10-27 02:07:27.548611 [DEBUG] switch_core_state_machine.c:585 (sofia/internal/3001@agilehive.ddns.me) Running State Change CS_REPORTING (Cur 1 Tot 946)
2020-10-27 02:07:27.548611 [DEBUG] switch_core_state_machine.c:936 (sofia/internal/3001@agilehive.ddns.me) State REPORTING
2020-10-27 02:07:27.648613 [DEBUG] switch_core_state_machine.c:174 sofia/internal/3001@agilehive.ddns.me Standard REPORTING, cause: NORMAL_CLEARING
2020-10-27 02:07:27.648613 [DEBUG] switch_core_state_machine.c:936 (sofia/internal/3001@agilehive.ddns.me) State REPORTING going to sleep
2020-10-27 02:07:27.648613 [DEBUG] switch_core_state_machine.c:611 (sofia/internal/3001@agilehive.ddns.me) State Change CS_REPORTING -> CS_DESTROY
2020-10-27 02:07:27.648613 [DEBUG] switch_core_session.c:1726 Session 946 (sofia/internal/3001@agilehive.ddns.me) Locked, Waiting on external entities
2020-10-27 02:07:27.648613 [NOTICE] switch_core_session.c:1744 Session 946 (sofia/internal/3001@agilehive.ddns.me) Ended
2020-10-27 02:07:27.648613 [NOTICE] switch_core_session.c:1748 Close Channel sofia/internal/3001@agilehive.ddns.me [CS_DESTROY]
2020-10-27 02:07:27.648613 [DEBUG] switch_core_state_machine.c:739 (sofia/internal/3001@agilehive.ddns.me) Running State Change CS_DESTROY (Cur 0 Tot 946)
2020-10-27 02:07:27.648613 [DEBUG] switch_core_state_machine.c:749 (sofia/internal/3001@agilehive.ddns.me) State DESTROY
2020-10-27 02:07:27.648613 [DEBUG] mod_sofia.c:364 sofia/internal/3001@agilehive.ddns.me SOFIA DESTROY
2020-10-27 02:07:27.648613 [DEBUG] switch_core_state_machine.c:181 sofia/internal/3001@agilehive.ddns.me Standard DESTROY
2020-10-27 02:07:27.648613 [DEBUG] switch_core_state_machine.c:749 (sofia/internal/3001@agilehive.ddns.me) State DESTROY going to sleep
2020-10-27 02:11:10.808614 [NOTICE] switch_channel.c:1118 New Channel sofia/internal/9031381411@3.138.141.1 [ae9382ec-17f9-11eb-8fd1-6f08f3e45e43]
2020-10-27 02:11:10.808614 [DEBUG] switch_core_state_machine.c:585 (sofia/internal/9031381411@3.138.141.1) Running State Change CS_NEW (Cur 1 Tot 947)
2020-10-27 02:11:10.808614 [DEBUG] sofia.c:10255 sofia/internal/9031381411@3.138.141.1 receiving invite from 212.83.177.158:52881 version: 1.10.2 -release 64bit
2020-10-27 02:11:10.808614 [DEBUG] sofia.c:10349 verifying acl "domains" for ip/port 212.83.177.158:0.
2020-10-27 02:11:10.808614 [DEBUG] sofia.c:2434 detaching session ae9382ec-17f9-11eb-8fd1-6f08f3e45e43
2020-10-27 02:11:10.808614 [WARNING] sofia_reg.c:1793 SIP auth challenge (INVITE) on sofia profile 'internal' for [90972594579544@3.138.141.1] from ip 212.83.177.158
2020-10-27 02:11:10.808614 [DEBUG] switch_core_state_machine.c:604 (sofia/internal/9031381411@3.138.141.1) State NEW
2020-10-27 02:11:20.848650 [WARNING] switch_core_state_machine.c:688 ae9382ec-17f9-11eb-8fd1-6f08f3e45e43 sofia/internal/9031381411@3.138.141.1 Abandoned
2020-10-27 02:11:20.848650 [NOTICE] switch_core_state_machine.c:691 Hangup sofia/internal/9031381411@3.138.141.1 [CS_NEW] [WRONG_CALL_STATE]
2020-10-27 02:11:20.848650 [DEBUG] switch_core_state_machine.c:585 (sofia/internal/9031381411@3.138.141.1) Running State Change CS_HANGUP (Cur 1 Tot 947)
2020-10-27 02:11:20.848650 [DEBUG] switch_core_state_machine.c:848 (sofia/internal/9031381411@3.138.141.1) Callstate Change DOWN -> HANGUP
2020-10-27 02:11:20.848650 [DEBUG] switch_core_state_machine.c:850 (sofia/internal/9031381411@3.138.141.1) State HANGUP
2020-10-27 02:11:20.848650 [DEBUG] mod_sofia.c:453 Channel sofia/internal/9031381411@3.138.141.1 hanging up, cause: WRONG_CALL_STATE
2020-10-27 02:11:20.848650 [DEBUG] switch_core_state_machine.c:60 sofia/internal/9031381411@3.138.141.1 Standard HANGUP, cause: WRONG_CALL_STATE
2020-10-27 02:11:20.848650 [DEBUG] switch_core_state_machine.c:850 (sofia/internal/9031381411@3.138.141.1) State HANGUP going to sleep
2020-10-27 02:11:20.848650 [DEBUG] switch_core_state_machine.c:620 (sofia/internal/9031381411@3.138.141.1) State Change CS_HANGUP -> CS_REPORTING
2020-10-27 02:11:20.848650 [DEBUG] switch_core_state_machine.c:585 (sofia/internal/9031381411@3.138.141.1) Running State Change CS_REPORTING (Cur 1 Tot 947)
2020-10-27 02:11:20.848650 [DEBUG] switch_core_state_machine.c:936 (sofia/internal/9031381411@3.138.141.1) State REPORTING
2020-10-27 02:11:20.848650 [DEBUG] switch_core_state_machine.c:174 sofia/internal/9031381411@3.138.141.1 Standard REPORTING, cause: WRONG_CALL_STATE
2020-10-27 02:11:20.848650 [DEBUG] switch_core_state_machine.c:936 (sofia/internal/9031381411@3.138.141.1) State REPORTING going to sleep
2020-10-27 02:11:20.848650 [DEBUG] switch_core_state_machine.c:611 (sofia/internal/9031381411@3.138.141.1) State Change CS_REPORTING -> CS_DESTROY
2020-10-27 02:11:20.848650 [DEBUG] switch_core_session.c:1726 Session 947 (sofia/internal/9031381411@3.138.141.1) Locked, Waiting on external entities
2020-10-27 02:11:20.848650 [NOTICE] switch_core_session.c:1744 Session 947 (sofia/internal/9031381411@3.138.141.1) Ended
2020-10-27 02:11:20.848650 [NOTICE] switch_core_session.c:1748 Close Channel sofia/internal/9031381411@3.138.141.1 [CS_DESTROY]
2020-10-27 02:11:20.848650 [DEBUG] switch_core_state_machine.c:739 (sofia/internal/9031381411@3.138.141.1) Running State Change CS_DESTROY (Cur 0 Tot 947)
2020-10-27 02:11:20.848650 [DEBUG] switch_core_state_machine.c:749 (sofia/internal/9031381411@3.138.141.1) State DESTROY
2020-10-27 02:11:20.848650 [DEBUG] mod_sofia.c:364 sofia/internal/9031381411@3.138.141.1 SOFIA DESTROY
2020-10-27 02:11:20.848650 [DEBUG] switch_core_state_machine.c:181 sofia/internal/9031381411@3.138.141.1 Standard DESTROY
2020-10-27 02:11:20.848650 [DEBUG] switch_core_state_machine.c:749 (sofia/internal/9031381411@3.138.141.1) State DESTROY going to sleep
2020-10-27 02:12:00.228644 [WARNING] sofia_reg.c:1793 SIP auth challenge (REGISTER) on sofia profile 'internal' for [3000@agilehive.ddns.me] from ip 82.129.86.122
agile
27
Please find attached the following
Gateway- settings
Inbound
Outbound - Dial plan
Access control
I will appreciate if someone can point me in the right direction.
Thanks in advance.
