SOLVED Inbound call not working?
JT000z
14
Hello Hello everyone
as I was trying to configure my SIP I can go out but I can't go in if I remove the provider from the ACL it says Auth is required when I add it, it says 480 Temp Unav.
and i attached a log with the last 150 KB and a screenshoot of sngrep with the request
  • freeswitch(3).txt
destination_number(fo359937ip279332_00) is the clue in the log file here. Look for this default setting, you probably want the ${sip_to_user} option.
Fairplay to Plusnet for filling RPID full of nonsense though! Real helpful from them. :rolleyes:
Once you've changed this, you'll have to edit or recreate your routes.
JT000z
14
Thanks for the reply I found my problem I choose the wrong name/number my SIP provider dosent go with numbers instead it went with my number o_O so after I replaced it it worked but thanks anyway
