Installing FreeSwitch Modules on FusionPBX
John
97
Does anyone know how to install freeswitch modules on a fusionpbx install?
I want to install mod_curl as an example
apt install freeswitch-mod-curl
Then edit /etc/freeswitch/autoload_configs/modules.conf.xml to load the module at startup.
covici
OK, so how do I install the module using the GUI? Right now I have an empty modules table in there -- this was the way it was installed.
John
97
He didn't mean you can install on the GUI. He meant instead of editing /etc/freeswitch/autoload_configs/modules.conf.xm AFTER installation, you can update the record using GUI.
covici
Well, I was hoping to add all the modules, so others could check things and do some maintainence, but I discovered that the module category could not be changed from other -- is this expected behavior? I thought you should be able to choose endpoints or whatever it was supposed to be.
