Can i set the internal and external calls to have different rings on the phones?
Andyd358 Member Aug 23, 2018 243 8 18 55 UK May 28, 2020 #1 Can i set the internal and external calls to have different rings on the phones?
K kapil Yadav New Member Jan 9, 2020 5 0 1 29 May 28, 2020 #2 Hi, Incoming calls disconnect as I tried to connect. the call is coming from a PSTN number and GS wave is registered in my phone. Please suggest
Andyd358 Member Aug 23, 2018 243 8 18 55 UK May 29, 2020 #3 kapil Yadav said: Hi, Incoming calls disconnect as I tried to connect. the call is coming from a PSTN number and GS wave is registered in my phone. Please suggest Click to expand... HI I think you need to create a new thread as then people may see what you ara asking
Andyd358 Member Aug 23, 2018 243 8 18 55 UK Jun 1, 2020 #4 Just to clarify We are using yealink phones and our customer whats his internal calls to sound ring different to external incoming calls.
K KonradSC Active Member Mar 10, 2017 166 98 28 Jun 2, 2020 #5 You can stick something like this in your dialplan. XML: <condition field="${call_direction}" expression="^inbound$"> <action application="set" data="sip_h_Alert-Info=<http://127.0.0.1/Bellcore-dr2>"/> </condition>
