IVR terminating at an extension instead of record.
toolfolks
73
I have created one IVR (IVR350 ) and assigned it to ext 350.
Created an inbound rule from the Dial plan.
See attached settings.
I can call ext 350 internally and I am using an inbound route to forward calls from a DID to the IVR.
I can select 1 or 2 and the calls and they transfer correctly.
After the time out instead of the exit action it transfers to ext 1005.
Any ideas ???????
toolfolks
73
I think the issue is it takes a long time for the changes in the exit action to register.
I changed the exit action to call an extension let it 5 mins re-stared freeswitch and it still didn't register for a while after.
