Limit Max Registrations per Extension
Andrew Byrd
309
I set Multiple Registrations Value=contact Enabled=true in Sip profiles internal
I reloaded XML and restarted FS
When I register two devices with the same extension only the first one that registered rings on incoming calls
Is there a place that I set the Maximum Registrations per extension? I see others talk about this but have yet to find where you adjust this number
The Registrations tab shows both devices registered and both can make outgoing calls. It's just the inbound that only rings the first one registered.
Andrew Byrd
309
I have come to Fusionpbx (Freeswitch) from the FreePBX world. In this world we used Pjsip extensions to have multiple registrations on one extension. In that world you can dial extension 101 and it will ring all devices that have 101 registered
In the Freeswitch world it will only ring the first device registered for ext 101.
I have to create a ring group, then call the ring group with 101 listed and it then rings all devices with 101 registered.
Simply put, I just need to mentally make the adjustments
Thank you for your info.
