mwi.lua
franklin1
When you clear the VMs out of the Message Center on a Polycom, but MWI will never appear again.
Been reading and found the post http://wiki.fusionpbx.com/index.php?title=Voicemail
when I run
fs_cli -x 'luarun app/voicemail/resources/scripts/mwi.lua'
I get this:
freeswitch@pbx.gran.com>
2020-07-13 14:57:58.708822 [ERR] mod_lua.cpp:202 ...eeswitch/scripts/app/voicemail/resources/scripts/mwi.lua:47: /usr/share/freeswitch/scripts/run/voicemail-mwi.tmp: No such file or directory
stack traceback:
[C]: in function 'assert'
...eeswitch/scripts/app/voicemail/resources/scripts/mwi.lua:47: in main chunk
I have a /etc/freeswitch/autoload_configs/lua.conf.xml
and
/usr/share/freeswitch/scripts/app/voicemail/resources/scripts/mwi.lua
In most cases we never need to use this script. The script is just designed to send out MWI reminder messages for phones that can't/don't remember their MWI state.
I think you are seeing the error because the script is unable to create the run file voicemail-mwi.tmp. Check that a directory exists called
/usr/share/freeswitch/scripts/run and that it is writable by the user that FreeSWITCH is running as (commonly www-data on Debian systems).
The purpose of the run file is that the script checks for its existence on each iteration of the program loop and if the file no longer exists it exits the script, thus providing a simple way of stopping the script.
If you are not seeing the MWI when a new message comes in, there may be another reason for that, I don't know enough about Polycom phones.
Reactions: franklin1
franklin1
Thank you. We seem to be getting a handle on this. In certain circumstances the Polycoms lose the message info. We're working with the scripts to suit.
That wiki is ancient and largely getting more and more useless all the time. It was brought back in an era when the official documentation was nowhere what it is now.
Dick Ollett
Interestingly
locate lua.conf.xml
returns both
/var/www/fusionpbx/resources/templates/conf/autoload_configs/lua.conf.xml
and
autostarting in /etc/freeswitch/autoload_configs/lua.conf.xml appears to work, not so much in
Scubadave112
122
19
Side note on this topic, I have been struggling to setup pager notifications for voicemails and couple of u seem very knowledgeable on MWI. I was wondering if I can somehow use MWI to trigger a script to to call a specified number every ten minutes until the voicemail is acknowledged or deleted.
Any advice I would even be willing to pay if someone can offer a solution to this
Interestingly
locate lua.conf.xml
returns both
and
The files you found under /var/www/fusionpbx are used in the install / upgrade process, it is the ones under /etc that are actually in use.
You may get more responses if you start a new thread for this question.
FusionPBX does not have such a facility currently, you could try putting in a feature request to the Fusion team. I don't think looking at MWI is the right way to go with this, but I like your thinking. FusionPBX does currently send out emails when voicemail arrives so it may be worth you looking at that mechanism.
Have a look at the code in /usr/share/freeswitch/scripts/app/voicemail/index.lua, look at the save function. Also have a look at the FreeSWITCH documentation for mod_voicemail, there is a lot of useful information there:
https://freeswitch.org/confluence/display/FREESWITCH/mod_voicemail
