Hello Everyone,
I am new here, i am trying to create a new broadcast type where i can upload the A numbers and B numbers separately and then when i start the broadcast campaign i can select the uploaded A numbers and B numbers that has been uploaded previously, Also i want to receive incoming to the same A numbers an B numbers once the broadcast campaign has been started. It goes like this, The incoming call should match the outgoing call from the broadcast campaign and fusionpbx should only allow incoming calls to the numbers that has been sent from the broadcast and should fail all other calls.
Please help me create this as i am new and also please let me on which file's i should make the changes.
Thank you.
Thank you.
