No ring on incoming and can't dial out with old GTE push button phone
arctic28
I'm trying to setup an old push button GTE telephone from the 80's with an HT802 on FXS port 1. I have it registered with fusionpbx. For incoming calls the phone doesn't ring the ringer bell but I can pick up the phone and audio works both ways. I tried the high power ring option which didn't seem to help. I also tried changing the ring frequency to 25Hz, which also didn't seem to help.
For outgoing calls I can hear the dial tone but after I dial a number I get some tones/beeps like something is wrong but not as harsh as the off hook tones.
I know things are correct on the sip side because I have basically the same config setup for the same extension on FXS port 2 that a new DECT phone is plugged into and works as expected for incoming and outgoing calls.
Any insight would be greatly appreciated!
arctic28
I’m not exactly sure what changed, if anything but I’m able to place an outbound call by pressing # after the number. But still don’t have the ringer working.
