outgoing calls not work
yeison.trejos
Hi all,
I have a fusionpbx on cloud and try connect with local pbx, the localpbx is behind of pfsense firewall, the calls from localpbx to fusion works fine but from fusionpbx to localpbx not, I see that in incoming calls the local pbx send request sip from port 52844, but in the outgoing calls fusion pbx try connect use port 36897, I set the proxy "xxx.xxx.xxx.xxx:52844" but not work the fusion pbx continue trying connect accross port 36897.
thanks your help.
