SOLVED postgres error
krooney
160
16
i am getting the following error in my logs and my system is memory is getting very high.
2021-03-12 19:11:10.322 EST [24754] postgres@fusionpbx LOG: could not receiv e data from client: Connection reset by peer
any help would be appreciated.
Thanks!
Ian Oakes
51
Are you running BDR? I cant remember the errors, but this could be that your node isnt talking to one or the other and the db changes are stacking up. If this is the case, it will fill the hard drive and take it down, bare that in mind.
