Provisioning issue
Incubugs
175
Hi guys, i have a new install 4.4 , its running on a debian 8 minimum in my vps. Everything is working fine apart from provisioning, i have enabled it in the advanced / default settings however when i add a device, give it a mac and save then allocate that to an extension no file is written to the server ? if i click the download link i get a 404 not found, any ideas ?
K
Incubugs
175
Hi, yes that was the issue, it appears that to create profiles for a domain you must access the system from that domain, well you live and learn thanks guys..
556
Its a security feature, it can be disabled.
http_domain_filter in default settings.
Incubugs
175
ahh i see it now, thanks for that. If i may how do i set the wallpaper for autoprovision on say a yealink for example, where does it pull the wallpaper from ? is it possible to upload my own on another webserver for example and get the phone to load that when it provisions ?
thanks again
556
No idea what that variable is, look in the default settings and if its not there look in the yealink provisioning guide to figure out how it needs to be added to the template.
