provisioning template for the yealink w70b base?
nktech1135
51
us
Hello.
Has anyone deplloyed the yealink w70b dect base yet? If so, which provisioning template did you use?
I was thinking of trying the one for the w60b to see if it would work. Any potential issues in doing this?
In my experience, Yealink are pretty good at not overhauling their config formats so a lot of the time you are safe to do so. You have to modify that y000000000.boot file so it points to the correct number for that release, like y00000000150.cfg. Someone showed me how to find that on the Yealink website many years ago, but I don't know how now and their website is pretty beans to navigate.
However.... W70B is already in the repo:
nktech1135
51
us
Thanks for this, I guess i'm to out of date to have gotten that. I made a copy of the w60b template and used that for provisioning. So far it works without modifying anything.
I did find a copy of yealink's official provisioning template and looked at that a bit, it only has the y000000000000.boot file, not a y00000000000xx.cfg file so i'm not sure, maybe that number doesn't matter anymore? As long as the correct includes are mentioned in the .boot file?
In any case, thanks for the help.
I found it definitely did matter, at least with the Yealink CP925. Don't ask me why, stumped me for about 2 days. Might be model specific!
I still can't understand why the Yealinks sometimes take the provisioning password and sometimes they just ignore it over and over again. I've had that problem for years though.
