SOLVED Provisioning URL Multi tenant
Claudio
Provisioning the first time via RPS works fine as long and fusion is configured correctly. The issue I have found with domain filter on and multiple domains I.e customerA.mycompany.com and customerB.mycompany.com is not pushed to the phone in the auto provision server URL field. So after the first provision from a defaulted phone you cannot push anything after that. The only solution I have found is to disable the yealink.provison.url line in the template so it maintains it from the RPS entry. Not sure how to configure this to have fusion push the right domain url to the endpoint.
Claudio
Try adding the specific domain url in advanced/domains as illustrated in the image, this should work:provisioningurl.jpg
This is from one of my live servers and it works just fine.
Claudio
I added that value in my domain and its not pushing that url to the endpoint. Using a T46G. Below is in my template. Not sure what else is missing.
## Autop URL ##
auto_provision.server.url = {$yealink_provision_url}
auto_provision.server.username = {$http_auth_username}
auto_provision.server.password = {$http_auth_password}
Thanks,
Claudio
