Provisioning Yealink T48S
pbx123
17
I setup a test server with the latest master branch and auto provision is working. The issue is that it will only provision the first 9 keys and ignores the rest. Is there a variable somewhere I need to change to get it to see the rest of the keys?
Using Yealinks software everything works as it should. Only in FusionPBX it won't provision more than 9 keys.
Upon further testing, keys 1-9 will program, 10-16 will not and 16-29 all program just fine.
It sounds like a bug to me in the "latest" master. There is no variable that I am aware of.
In the device records, have you tried the "Files" button to see what would actually be downloaded to the phone?
pbx123
17
Thanks for the reply. Yes, I checked the files and all return 200 from Nginx as being found and it looks like all of the files are there. Seems odd that it just skips 10-16 then picks up the rest ok beyond that.
pbx123
17
Thanks. I checked and looks like the files are the same as yours. I even downloaded the latest templates from the master for the T48S and no change.
So when you click on the <mac>.cfg in the dropdown list, it will download the config to your computer that it would normally send to the phone. Then you can see what is being set for the keys 10-16. It will show you the template file with all the values filled in from your device settings.
Reactions: pbx123
pbx123
17
Thanks that helps a lot. I looked at the .cfg file and everything looked the same for 10-16, just like the other keys. I defaulted the phone again to factory settings and 10-16 are now working. Thanks again, really appreciate the help!
Reactions: Adrian Fretwell
