Recommend phone for retirement home resident
ZPM
64
Looking for recommendations for a phone to use for residents in reitrement home facility. Needs to be a phone with very little features.
Ian Oakes
51
anything not from grandstream...
Sorta kidding, but i really did dump everything from them except the gateways and atas.
It kinda depends on how you want to deploy the phones, if you want to run copper then use a gateway, they have a couple of good and fairly stable models. If you want voip phones, look at the yealink t19, t40s and polycom has a new really simple phone but the model escapes me.
ZPM
64
Thanks for these great suggestions I found also the Fanvil H2S that would be perfect . The model does not have a template listed in Fusionpbx but probably would still work just fine.
