Ringback tone not sent to all sip clients
102
2021-07-31 14:19:06.234080 [DEBUG] switch_ivr_originate.c:1407 Play Ringback Tone [%(400,200,400,450);%(400,2000,400,450)
I have two internal extensions, one is running Zoiper Client and another is running Sipnetic.
When I call from Zoiper to Sipnetic - I don't hear a ring back tone at all - it is silent, however calls do get established and when the other party answers, audio works.
When I call from Sipnetic to Zoiper, I get the above line in the freeswitch logs where the server is sending a ringback tone, and I hear a ringtone but it is a US ring tone and not a UK ringtone. (this is a separate issue)
I tried using Linphone - when I use that again I hear no ring back tone on the client, the server doesn't send the
All the extensions reside on the LAN and there is NO NAT involved, Can you let me know what needs to be looked at to resolve this?
I looked at a similar issue here but there was no resolution
Jul 15, 2021
102
Just to add to the issue: Ring back tone is heard on Zoiper client when an external call is made, i.e from Zoiper ->freeswitch -> external call
Zoiper->Freeswitch->internal - no ringback tone
Jul 15, 2021
102
Just an update, this seems to be an issue when Opus module is enabled and Opus codec is set in preferred codecs. When I remove Opus and just have PCMA, the ring back tone is heard.
