[Solved] *732 IVR recorder hangs up right before recording starts
rchase
Ran into a weird issue today on FusionPBX 4.2.1 when I went to record an IVR for one of my domains.
I dialed *732 from my phone, entered the recording pin code, then entered 100 for recording name. The call then immediately hungup.
After a look at fs_cli, the problem was that a directory had not been created for domain in the recordings folder.
/var/lib/freeswitch/recordings
So I did:
mkdir /var/lib/freeswitch/recordings/mydomain.mysite.tld
chown www-data:www-data /var/lib/freeswitch/recordings/mydomain.mysite.tld
The recordings work now for that domain
Feb 18, 2017
I had the same thing. Wish I had seem this post first...
What is the best practice for a domain name for Fusion. Right now mine in the lab is using my internal IP Address.
Thx,
Scott
rchase
Hi Scott
I use cloudpbx.mydomain.com as the main login and then i have companyname.mydomain.com for each tenant
Feb 18, 2017
Hey, thx for the reply. In a standalone deployment, are there any drawbacks to just using the ip address of the server?
rchase
It will work just fine, the only drawback being that you cannot do multi-tenant without DNS names.
The IP address can serve as a single domain
Reactions: Scott Williams
It will work fine but for security purposes it is better to use a domain name. That way the IP address can be left for Mr Hacker but because we know it is only Mr Hacker coming there we can do things like block for a month anything that so much as sniffs at the IP.
