(SOLVED) Email settings not updating
Andyd358
243
UK
Im trying to setup the emails settings on a fresh install and seem to be having an issue in that even if I chnge the details under default settings they donet seem to be updating. When I send a test email its using the original details I entered in the settings. Also Im unable to send any test emails and get the following error:
SMTP -> FROM SERVER:220-ns5.synthesis-it.co.uk ESMTP Exim 4.94 #2 Thu, 15 Apr 2021 16:17:32 +0100 220-We do not authorize the use of this system to transport unsolicited, 220 and/or bulk e-mail.
SMTP -> FROM SERVER: 250-ns5.synthesis-it.co.uk Hello ip172.ip-188-165-112.eu [188.165.112.172] 250-SIZE 52428800 250-8BITMIME 250-PIPELINING 250-X_PIPE_CONNECT 250-AUTH PLAIN LOGIN 250-STARTTLS 250 HELP
SMTP -> FROM SERVER:220 TLS go ahead
SMTP -> FROM SERVER:ecurity failure 554 Security failure
SMTP -> ERROR: RSET failed: ecurity failure 554 Security failure
SMTP -> FROM SERVER:554 Security failure
SMTP -> ERROR: MAIL not accepted from server: 554 Security failure
The Error on the mail server is :
2021-04-15 16:20:21 SMTP connection from [188.165.112.172]:57218 (TCP/IP connection count = 1)
2021-04-15 16:20:21 TLS error on connection from ip172.ip-188-165-112.eu (fusionpbx) [188.165.112.172]:57218 (SSL_accept (TLSv1.2)): error:140760FC:SSL routines:SSL23_GET_CLIENT_HELLO:unknown protocol
2021-04-15 16:20:21 SMTP connection from ip172.ip-188-165-112.eu (fusionpbx) [188.165.112.172]:57218 closed by EOF
Like i said if I alter say the email address or username/password under default settinigs they dont seem to be updating. The test email is being sent as the original settings I entered.
