SSL Certificate on Web Portal
i3ioi-iazard
52
Pretty simple question I hope...
When I want to add a SSL Certificate to my pbx for the FusionPBX portal, will this impact any existing setups that I have? I am going to follow this link https://docs.fusionpbx.com/en/latest/getting_started/lets_encrypt.html . Is this the correct link to follow? I am only looking to have a secure page for the portal.
The environment is currently in production so i don't want any calls to be interrupted or provisioning to stop working etc.
Thanks!
JamesBorne
294
56
Australia
Calls have nothing to do with web content, so no interruption to calls while messing around with Nginx.
Provisioning will be interrupted (for 15 seconds?) as that does require web based content.
As always, if you are unsure on a production box, the smartest thing to do is create a test system. With installer it should take you 15 minutes tops to have a DNS record and a test Fusion instance.
