D dbz195 Member Feb 3, 2021 87 5 8 38 Mar 2, 2026 #1 Question: For FSPBX do you still follow the same rule as fusion for the "external_rtp_ip/sip_ip" set, to a static ip or leave it as the default
P pbxgeek Well-Known Member Jan 19, 2021 947 308 63 39 Mar 2, 2026 #2 In most environments that I had worked in, I ended up needing to set those values up. The hostname, too, if replication is involved.
