Stopping Replication
Matthew Main
92
Hey guys,
I have a 2 node DigiDaz cluster running, i need to stop replication and remove node 2, I have been looking at the standard bdr commands that i guess run under psql but there not working, can anyone point me in the right direction
KR
Matt
KonradSC
166
98
I've had to remove BDR manually before for various reasons. If the standard bdr commands didn't work I would go to Node 1 and remove Node 2 from it's bdr.bdr_nodes and bdr.bdr_connections table.
These are my notes: ...good luck
Commands to remove a broken NODE2:
Remove the node from the cluster. Execute the following on NODE1
    SELECT bdr.bdr_part_by_node_names(ARRAY['node2-fdb2']);
    select * from bdr.bdr_nodes;
    delete from bdr.bdr_nodes where node_status='k';
    select * from bdr.bdr_connections;            #remove old connections if stuck
To remove BDR from NODE2:
su -l postgres
psql fusionpbx
    select bdr.bdr_get_local_node_name();
    select * from pg_replication_slots;
    select pg_drop_replication_slot('bdr_795788_6388070180857753308_1_5751674__');
    delete from bdr.bdr_nodes where node_status='i';
select bdr.remove_bdr_from_local_node();
DROP EXTENSION bdr;
DROP DATABASE fusionpbx;
Reactions: Matthew Main
Matthew Main
92
Thanks for the help, I found the error of my ways, i was not entering a DB before running the commands.
so i have run the above on all db being replicated (fusionpbx and freeswitch), All i want to do is stop node 1 filling up with failed syc logs. I have built a new cluster on 4.4 and to save monies dropped the node 2 from the original cluster while i migrate all data over.
will running just the 1st section be enough?
Cheers Matt
KonradSC
166
98
Yeah, just the first part is all you need. I have the 2nd step in my notes for when I need to break BDR and set it up again on Node 2. If the server is being decommissioned then just shut it down and remove the entries on Node 1 BDR tables.
Vishal Pai
Hello Everyone
I am having 4 server with replication using bdr. All 4 are replicated together now i want to remove/destroy the 3rd one out of 4. What is the best way to achieve it.
As i can see above post shall i go to individual node and run below command
or any other way is there to achieve it.
