Turn Off Active Call Recording
Matthew Main
92
Hi Guys,
Need a little help, I need a feature code to turn off call recording during a call and also re-enable call recording during a call.
Can anyone help?
This is due to a client taking Credit Card numbers over the phone. We need to stop the recording during that time and then record once sensitive details have been taken
Kind Regards
Matt
Matthew Main
92
been reading how to do this in freeswitch and wondering if all I need to do is add the action application into the inbound and outbound route.
the info is in a good freeswitch cookbook :)
can someone shed more light on this, please
I cannot remember exactly how to do this if I remember correctly FusionPBX uses the uuid_record function.
Within it there is an option to mask part of the recording, see: https://wiki.freeswitch.org/wiki/Mod_commands#uuid_record
I think you need to call mask then unmask, you would have to grab the uuid of the call.
uuid_record <uuid> mask /path/to/file/recording.wav
So you need to get UUID and recording path of the call.
If I remember correctly:
uuid_getvar 2f4444f0-b681-11e6-a048-cf63bb376a7e api_on_answer
will help with this, Where uuid of the call is yours obviously.
Hope it helps.
Matthew Main
92
ok so it is call masking that i am after, is there a way to just create a short / feature code to handle this. I have googled and not found much, little stuck
i would have though with PCI / DSS compliance this would be a standard feature code in fusion / freeswitch
ThriveLife
12
I'd like to add my need for this exact requirement for PCI compliance. I've attempted to create a 'Payment' that our CS reps transfer to which doesn't have recordings enabled, but after a xfer from Support to Payments, the call continues to record. We need to record our call data, just not when we collect payment. Anybody else have any success here?
With regards to PCI compliance, I am surprised that they accept the operator activating the masking.
Did you guys get a solution to this? I have one which should be completed today. I need to do some further testing.
ThriveLife
12
I'm still tinkering around with it, my latest approach has been to turn off recording in the call center queue and use the dialplan to start and stop recording, but I've hit a block on hangup not stopping the recording. I'd love to see what you've discovered :)
Right, very tatty for now (I've dropped the bind digits into the variables part of the dialplan)
action bind_digit_action local,*789,exec:lua,toggle_recording_masking.lua,${bind_target}
Then in the following file:
/usr/share/freeswitch/scripts/toggle_recording_masking.lua
        require "resources.functions.config";
        require "resources.functions.settings";
--make sure the session is ready
        if ( session:ready() ) then
                --set the sounds path for the language, dialect and voice
                        default_language = session:getVariable("default_language");
                        default_dialect = session:getVariable("default_dialect");
                        default_voice = session:getVariable("default_voice");
                        if (not default_language) then default_language = 'en'; end
                        if (not default_dialect) then default_dialect = 'us'; end
                        if (not default_voice) then default_voice = 'callie'; end
                --get the variables
                if (session:getVariable("masked") == null) then
                        masked = "false";
                else
                        masked = session:getVariable("masked");
                end
                uuid = session:getVariable("uuid");
                path = session:getVariable("api_on_answer");
                path = string.gsub(path, ".* start ", "")
                --mask or unmask the recording
                api = freeswitch.API();
                if (masked == "false") then
                        cmd = "uuid_record "..uuid.." mask "..path;
                        sound = "uuid_broadcast "..uuid.." "..sounds_dir.."/"..default_language.."/"..default_dialect.."/"..default_voice.."/ivr/ivr-recording_paused.wav both";
                        api:executeString(sound);
                        api:executeString(cmd);
                        session:setVariable("masked", "true");
                else
                        cmd = "uuid_record "..uuid.." unmask "..path;
                        sound = "uuid_broadcast "..uuid.." "..sounds_dir.."/"..default_language.."/"..default_dialect.."/"..default_voice.."/ivr/ivr-recording_started.wav both";
                        session:setVariable("masked", "false");
                end
        end
Let us know how you get on :)
Hang fire with the above, there are multiple problems, but I think I'm just nailing them...
ThriveLife
12
Thanks Daz. I created a checkpoint on the VM so I'll play around with the above until you think you nail it down. Thanks!
Rick Hodger
I made some modifications to DigitalDaz's script and it works for me now.
                --get the variables
                        masked = "false";
                else
                end
                uuid = session:getVariable("bridge_uuid");
                        freeswitch.consoleLog("notice", "[recording] Masking call "..uuid.."\n");
                        freeswitch.consoleLog("notice", cmd);
                        reply = api:executeString(cmd);
                        if (string.sub(reply, 0, 1) == "-") then
                            sound = "uuid_broadcast "..uuid.." "..sounds_dir.."/"..default_language.."/"..default_dialect.."/"..default_voice.."/misc/error.wav both";
                        else
                        end
                else
                       freeswitch.consoleLog("notice", "[recording] Unmasking call "..uuid.."\n");
                        else
                        end
                end
        end
To explain the changes I made:
  • The recording appears to be started under the bridge UUID, and not the leg UUID.
  • I added in checks for errors in case the recording fails to mask/unmask, and announce that it has failed to the call. In the original script it would fail silently and announce that recording was paused, when in actual fact it continued to record.
Reactions: DigitalDaz
Nice, I had fixed this for the leg UUID but hadn't put in any checks so that's good to see, I'll dig around and see what else I have because the inbound causes a little grief too, I know in a couple of places, maybe ring groups, the bindings are hard coded so though your outbound may work, mileage will vary on the inbound depending on how they are routed in.
Rick Hodger
I hadn't actually tested transferring the call.
It does seem to work, with one small problem. If I answer a call, mask and unmask and then transfer - the new party can still mask and unmask the call, no issues with the recording. If I answer a call on extension 101, mask the call and transfer to extension 102, the recording remains masked. If ext 102 dials *9, the script attempts to mask the call again - the 'masked' variable does not appear to carry over after the transfer.
Edit: I'm guessing that the masked var is being stored in the leg of the call, rather than the bridge, and gets destroyed or left behind when the call is transferred. I can't see a way to store the variable in the bridge.
