Upgrade from v4.5
glennbtn
I still have an old server running 4.5 that I want to now get up to date.
I am trying to follow the upgrade path following Fusion documentation which the 1st step is to go from 4.5 to 5.
I have moved the old fusionpbx folder, and done a git clone as per the instructions, followed by doing the chowning
The next set is to run the upgrade.php, this is where it all falls down.
PHP Warning: syntax error, unexpected '(' in /etc/fusionpbx/config.php on line 7
in /var/www/fusionpbx/resources/classes/config.php on line 189
PHP Warning: array_key_exists() expects parameter 2 to be array, bool given in /var/www/fusionpbx/resources/classes/config.php on line 115
PHP Warning: count(): Parameter must be an array or an object that implements Countable in /var/www/fusionpbx/resources/classes/config.php on line 293
PHP Fatal error: Uncaught TypeError: Return value of config::configuration() must be of the type array, bool returned in /var/www/fusionpbx/resources/classes/config.php:301
Stack trace:
#0 /var/www/fusionpbx/resources/require.php(45): config->configuration()
#1 /var/www/fusionpbx/core/upgrade/upgrade.php(28): require('/var/www/fusion...')
#2 {main}
thrown in /var/www/fusionpbx/resources/classes/config.php on line 301
php -l /etc/fusionpbx/config.php shows no errors and though it may be php as this server had 7.1 so upgraded to 7.4 but still the same
Anyone got any ideas
You for sure need PHP 8.1 to start. 7.4 will likely to have errors. There might be other things you will need to adjust.
I have now tried on 8.1 but still errors. Shame anything like this is not in the document
PHP Fatal error: Uncaught TypeError: array_key_exists(): Argument #2 ($array) must be of type array, bool given in /var/www/fusionpbx/resources/classes/config.php:115
Stack trace:
#0 /var/www/fusionpbx/resources/classes/config.php(258): config->__get()
#1 /var/www/fusionpbx/resources/classes/config.php(197): config->get()
#2 /var/www/fusionpbx/resources/classes/config.php(59): config->define_project_paths()
#3 /var/www/fusionpbx/resources/classes/config.php(310): config->__construct()
#4 /var/www/fusionpbx/resources/require.php(35): config::load()
#5 /var/www/fusionpbx/core/upgrade/upgrade.php(28): require('...')
#6 {main}
thrown in /var/www/fusionpbx/resources/classes/config.php on line 115
what code do you have on line 115 in this file?
Text-based support will only get you so far. Call the number on this page so you can get it done faster, easier. You will reach an expert who knows FusionPBX extremely well, and they can help you with the upgrade.
- https://www.fusionpbx.com/support
Tip: can skip the version in between and go directly to the latest version. Then you can go through each version upgrade guide to make sure nothing was missed.
Still waiting for your call.
