SOLVED voicemail box manager.
derr12
17
So far I really like the voicemail manager from the webgui, I was wondering if there was a way to let users in to view/edit their own voicemail without being able to see everyone elses.
So far the only way i have found to allow access to a user mailbox manager is by granting view/edit permissions and adding the app from the menu manager. unfortunately this gets you access to all mailboxes.
derr12
17
by default (user, agent groups) all you get on the dashboard is your extension settings. in the apps menu thereis voicemail but it gives you an access denied error.
derr12
17
in the upgrade screen defaulted all the settings and getting assigned voicemail boxes in the dashboard now.
Reactions: DigitalDaz
