Voicemail problems
kobus.morgan
38
Hi Guys,
Hope someone can point me in the right direction.
Ive recently found a problem where voicemail messages are not playing when you dial *97 and go through the prompts. Tells you to press 1 to listen, which I then do. The prompt continues by giving the time, date and number. Thereafter message should play. Only goes to the prompt again telling you to press 1 to listen, etc.
I am not 100% on how to trace the sessions to see whats happening.
Any help would be great.
At the linux command prompt try fs_cli and look at the log that way.
There should also be a log at:
/var/log/freeswitch/freeswitch.log
kobus.morgan
38
Hi DigitalDaz,
Thanks for the info.
I actually did that. It does show when the voicemail kicks in. It only shows the prompts that play and nothing wrt the actual message that was left.
I would have suspected that it would give you some indication of the actual weirdCHars.wav file that the voice message was stored as but nothing as far as I can tell.
