want to received incoing call on freeswitch ip and port 5060 using fusionpbx
Ankit
Hello All,
I m using free switch 1.6.20 version with fusion pbx version 4.2.3.
we have 1 NEC PBX they call transfer all incoming all to my free switch ip and port 5060.
I have create 1 trunk with internal profile with NEC PBX IP(IP BASED TRUNK) but unable to received call but get incoming request,it's give me falling back domian please check your acl.conf message in console.
I have already NEC PBX IP address into acl with allow permission but still get the same.
can anyone have any idea about that?
Ankit
i have already added and it's display in list .
Here you can check incoming logs while receiving any request from NEX PBX
2018-05-22 11:59:14.274208 [WARNING] sofia_reg.c:2906 Can't find user [@192.168.51.253] from 192.168.12.105
You must define a domain called '192.168.51.253' in your directory and add a user with the id="" attribute
2018-05-22 11:59:14.274208 [WARNING] sofia_reg.c:1737 SIP auth failure (INVITE) on sofia profile 'internal' for [3006@192.168.51.253] from ip 192.168.12.105
