Wrong caller number
radial
Hi everyone,
I have a problem witch my sip trunk to slican telephony excange.
When i trying to call from slican to Freeswitch I see slican_voip username instead number, while in caller name it's proper number.
In gateway configuration I set Caller ID In From to true but problem still exists.
The above causes problem with redial function because freeswitch refusing connection with busy signal.
Is it a possible to remap caller name to caller number ?
Without seeing a packet capture of the inbound call it is difficult to diagnose but in Gateway Advanced, you could try setting Extension to auto_to_user
radial
After few hours of debuging I resolved a problem.
Solution was changing CLIP session presentation from default to Remote Party ID in voip translations settings on Slican.
Now freeswitch shows proper number
