Having an issue it getting provisioning working. Went throught the docs, forums, videos, etc. ad nauseam and all variables look like they are set correctly. Rebooted Fusionpbx and no change.
I setup a test install with current FusionPBX v4.5.15 master to get provisioning working with the Yealink T48S phones.
I added the username / password on default settings in the provision section and enabled to true.
Added domain.com/app/provision to yealink_provision_url, and set enabled to true.
Added the mac address in the extension.
Devices: Press provision, it flashes Check Sync +OK Applied, flashing indicator on the phone but nothing gets updated. If I press the speaker key it clears the phone status flashing indicator.
When I click provision in Registrations I get - Registrations Provisioned - ERR no reply. The phone status light starts flashing, but nothing is updated. I press the speaker button to turn off the light. No errors in the phone, fs_cli (debug=7) or nginx logs. I can press reboot under registrations for that extension and it reboots the phone.
I can click auto provision in the yealink software, phone indicator flashes, but still has the same info that was setup in the yealink interface. Acts the same way that Fusionpbx does when trying to provision.
I can access the templates via the url and auth works as I have to use the username/password to access.
Is there anything I need to edit in templates or .cfg files to get it working? All the files are found according to the nginx logs when I try to provision.
