503 service error on incoming calls
scg_chris
11
Knoxville, TN
It seems the server stops working after about ~130 concurrent incoming calls hitting an IVR at a single time. I need the system to support 700+ concurrent calls at any given moment. We are currently in testing, but where can I look in FusionPBX setting for something that could be limiting call volumes.
Thanks!
377
When you get the 503, do you see an entry in the FreeSwitch log file?
What happens with the same number of concurrent calls but not hitting an IVR?
Have a look at your default settings in /etc/freeswitch/autoload_configs/switch.conf you may be hitting the sessions-per-second limit.
scg_chris
11
Knoxville, TN
I found this in the logs`2020-05-08 02:16:56.723819 [CRIT] switch_core_session.c:2357 Throttle Error! 87`
I did update the switch.conf.xml file to have 1000 sessions per second.
had to restart, but its working perfectly now! Thanks @Adrian Fretwell
freeswitch@ip-172-31-12-33> status
UP 0 years, 0 days, 0 hours, 19 minutes, 34 seconds, 798 milliseconds, 138 microseconds
FreeSWITCH (Version 1.10.2 -release-14-f7bdd3845a 64bit) is ready
2201 session(s) since startup
0 session(s) - peak 1080, last 5min 1080
0 session(s) per Sec out of max 1000, peak 71, last 5min 70
2000 session(s) max
min idle cpu 0.00/35.30
Current Stack Size/Max 240K/8192K
Reactions: Adrian Fretwell
377
Your seconds per second still shows max 30. You can look at and change the sessions-per-second values at the fs_cli with:
fsctl sps
or to set it:
fsctl sps 100
