7 min 29 Sec inbound call Cutoff
103
Hi All
We are losing all calls from our providor at 7mins 29 seconds.
In SNGREP and the CDR we have the message
Reason: Q.850;cause=96;text="MANDATORY_IE_MISSING"
Any pointers would be amazing.
Kind Regards
Andy
May 16, 2017
103
@DigitalDaz
This is the same BT providor - Im still waiting on them sorting out the outbound but this issue started occuring Monday. We cant see an examples before then.
I captured a trace exactly around the time it went down. I just traced external profile. Is there anyway to set the trace against the gateway.
sofia profile external siptrace on
  • Sip Trace.txt
566
Here looks to be the reason:
018-06-08 10:49:14.540960 [ERR] sofia_reg.c:2616 Cannot locate any authentication credentials to complete an authentication request for realm '"jdevo.com"'
2018-06-08 10:49:14.540960 [NOTICE] sofia_reg.c:2639 Hangup sofia/external/07946822853@jdevo.com [CS_EXECUTE] [MANDATORY_IE_MISSING]
So my guess is there is some sort of reinvite caused by the session timers being enabled:
INVITE sip:07946822853@62.7.201.169:5060 SIP/2.0
Via: SIP/2.0/UDP 52.51.48.253:5080;rport;branch=z9hG4bKjjar6m2B2392B
Max-Forwards: 70
From: "01282 678401" <sip:441282678401@jdevo.com;user=phone>;tag=U4S01aD2r050j
To: "+447946822853" <sip:07946822853@jdevo.com>;tag=3737439697-471166132
Call-ID: 10294995-3737439697-809996478@sbc-uk-bs09b.ipcomms.bt.net
CSeq: 123889613 INVITE
Contact: <sip:441282678401@52.51.48.253:5080;transport=udp>
User-Agent: FreeSWITCH
Session-Expires: 900;refresher=uac <---------------------------------------------
Min-SE: 120 <----------------------------------------------------------------------------
Content-Type: application/sdp
Content-Disposition: session
Content-Length: 220
I would check the gateway config though I do not understand why the call would even initiate.
Its implying there is no username/password in the gateway.
May 16, 2017
103
Thanks for this, I put the dmoain into "realm" and this fixed it :)
Still haveing issues with sending outbound. - Latest update from providor was they think SIP ALG is on the network the PBX resides but its in AWS with a public facing IP so i cant think its that.
