Active calls on admin dashboard
sokalsondha
37
hello everyone
can someone help me to guide me that how can i bring the active calls page in the dashboard? i want to do that for admin. so when admin login to the panel he can see live calls directly from the dashboard without going to the menu.
i try to look in the default settings. but its not there? any help?
thanks
413
You can already see an active call leg count with channels in the dashboard. Channels is also a link to the active calls application, so you can get there in one click.
Displaying active calls can be quite a heavy work load for the server so I would not advise having it display by default.
markjcrane
499
177
I agree as well with current design it would not be a good idea to bring active calls into the dashboard. Also note the dashboard will be getting a major overhall. Expect custom code to require work to be done over again after the dashboard is updated.
